Ls ecu
what are the numbers for the usdm integra LS ecu i want to make sure i am running the correct ecu cause my car runs a little funny. i was told it was a timing problem but i check the cam timing and the ignition timing and both are fine. my problem is then the car is in neutral just idling it will be at say 800 rpms and it will bog down a little then go right back up it also does it while driving and it dosent just feel like its just a bad idle it feels like there is a strain on the motor. any info on the ecu or my problem is appreciated thanks.
bseries_beast
Apr 30, 2007 03:32 PM
