reverse lights stays on when car is started and cluster not lighting up
Old Mar 25, 2009 | 10:46 PM
d_EG COUPE's Avatar
Icon3 reverse lights stays on when car is started and cluster not lighting up
well i picked a shell from my friend last night its a 92 honda civic si. so i put the d16z6 in. started it no problems but when i looked in my rear view and seen white light so i hopped out the car and and seen my reverse lights on. WTF? lol. so it never went away. so after that i checked everything else to see if theres anything else funky goin on on so i turn the lights on and the cluster dont light up. i checked the bulbs and even tried 2 other clusters. none of them work. would any one know the problem to either. thanx.
PROBLEMS " if u got lost in my story"
1. reverse lights stay on when car is started
2. cluster dont turn on
thanx
Old Mar 25, 2009 | 11:12 PM
d_EG COUPE's Avatar
Default Re: reverse lights stays on when car is started and cluster not lighting up
any1
Old Mar 26, 2009 | 12:57 AM
tazeat's Avatar
If you unplug the reverse sensor from the tranny does it turn off?
If it does, its a bad reverse sensor on your tranny. Answer this and if its not someone can help you diagnose more difficult wiring problems...
Old Mar 26, 2009 | 06:16 AM
marcs1337's Avatar
reverse sensor on trans or a short to power in the reverse light circuit
Old Mar 27, 2009 | 09:35 PM
d_EG COUPE's Avatar
and about the reverse light situation whenever i take i the fuse 10a for backup light out it go's way but my turn signals dont work. but when its in reverse light says on. where is the reverse sensor on the tranny?
Old Mar 27, 2009 | 09:42 PM
hatchlover71890's Avatar
it is the two wires toward the front of the lower side of the tranny, they run inside the tranny through a gromet, they also have butt connectors, make sure they are securely connected
Old Mar 27, 2009 | 09:43 PM
jagass's Avatar
It just happened to my buddy a few weeks ago...I will ask him for help...
Old Mar 27, 2009 | 09:47 PM
Former User's Avatar
For the gauge lights, check whether the dash lights brightness controller (DLBC) dial is turned all the way OFF and whether fuse 19 under the dash is blown. If those ideas don't help, then remove the DLBC, uncouple the connector, and put a jumper wire between terminals for the Red and Black wires. The dash lights should illuminate at full intensity when the parking lights are turned ON from the combination switch.
Old Mar 27, 2009 | 09:56 PM
Back-up lights:
1) Check fuse 15 again. Use a multimeter to check for continuity actross the two terminals.
2) Troubleshoot the switch. Manual transmission, right?:
Old Mar 27, 2009 | 10:31 PM
d_EG COUPE's Avatar
yeah manual
Old Mar 27, 2009 | 10:43 PM
d_EG COUPE's Avatar
the picture really doesnt show me where its at... can some tell me like juss an example
Old Mar 27, 2009 | 10:45 PM
d_EG COUPE's Avatar
thanx for this much help guys really appreciate it
Old Apr 6, 2009 | 07:52 PM
d_EG COUPE's Avatar
would any1 have a pic?
Old Apr 6, 2009 | 08:17 PM
Old Apr 6, 2009 | 08:51 PM
d_EG COUPE's Avatar
ok thank u will check tomorrow when i get back home!
Old Apr 8, 2009 | 06:57 PM
d_EG COUPE's Avatar
so yeah it is the reverse sensor... thanx every1
Unphzd
Jan 13, 2011 06:42 AM
EusebioSam19
Oct 24, 2010 08:20 PM
mickeey
Mar 11, 2009 07:18 AM
DoWnfall
Nov 9, 2008 08:33 AM
snuggles
Apr 7, 2005 10:58 PM
