search didnt help Insight hybrid
Old Aug 13, 2002 | 04:21 PM
Turb0Minnow's Avatar
Default search didnt help Insight hybrid
Anyone ever build one? maybe a b16 in a insight? I was looking under the hood and noticed that in has plenty of room so does anyone know if a b series will fit?
Old Aug 13, 2002 | 08:32 PM
Freakn8's Avatar
Default Re: search didnt help Insight hybrid (GTRsi)
The insight is designed to save gas, you're never gonna be able to pull out all the batteries and swap in an engine
If you want a small light car to do a swap in get a CRX
Old Aug 13, 2002 | 08:42 PM
brian g's Avatar
I am working on trying to get a car.
brian g
Old Aug 13, 2002 | 10:11 PM
NegativeLift's Avatar
Default Re: search didnt help Insight hybrid (brian g)
The Insight is an aluminum frame and should be the lightest chassis available from Honda. What makes it heavier (still only 1900lbs if i remember right) is the electric motor parts), but there are NO batteries!
Old Aug 13, 2002 | 10:33 PM
v4lu3s's Avatar
RTFM
Default Re: search didnt help Insight hybrid (NegativeLift)
then why does honda keep talking things like this:
VTEC™-E gasoline engine, the Insight drives just like any other automobile. It has a 10.6-gallon gas tank, and no external power supply is needed for recharging. Batteries are recharged by regenerative braking. Specifically, energy from forward momentum is captured during braking. This energy is then used to recharge the batteries.
http://www.hondacars.com/models/insi...gineering.html
the charts at http://www.fueleconomy.gov/feg/tech/...ightFINAL2.pdf also show a large battery pack...
Old Aug 14, 2002 | 05:16 AM
brian
http://www.edmunds.com/new/2002/hond.../photo_11.html have you had a chance to look under the hood of one? it certianly seems possible. I would think you would have to relocate the battery(the one that starts the mech motor) to the hatch. there is also a large crossbeam/member that runs right next to the firewall. I would assume it is used for some kind of chassis stiffener.
Old Aug 14, 2002 | 05:19 AM
Default Re: search didnt help Insight hybrid (v4lu3s)
if you also notice that under teh hb area there is what seems to be an Al panle that hides the battery pack and the other electronics.
Kris Ramesa
Mar 5, 2014 12:32 PM
RubberGloveBoii
Classic Hondas
Oct 30, 2011 09:59 AM
tekstyle
Honda Fit
Jun 20, 2006 11:54 PM
Kaji
Apr 12, 2006 08:00 PM
allmotorcrx1987
Mar 21, 2006 08:38 AM
