revs when starts
i have a 92 lx with a z6 i just got the car it wasnt runing and guy had plugs in all different spots will it has the si/ex engine harness on it and still has the sedan lx chassie harness but yea when i start the car it revs up to about 5k and if i unplug the iac valve then it idle hops from like 1k to 3k there is a p05 ecu runing i know i need to change it out for a p28 but i figured it would at least idle and run decent and just not have vtec but yeah c if you u guys have any idea on this i am stumpd and lookin for advise
thanks
cody
thanks
cody
Clean the IACV. If that doesn't fix it, get the right ECU (you should get the ECU either way). If neither works, get a new IACV.
Isn't the P05 for the D15B8 (8 valve engine)? I don't think a Z6 will run so well on a P05 ECU.
Get the right ecu! I've had similar issues, it turned out to be the combination of a broken TPS and a vacuum leak.
WolfGod
Jul 11, 2006 05:25 PM
mikeunreal2
31
Mar 12, 2006 10:28 PM
