on/off fan switch
Old Mar 25, 2009 | 09:17 PM
ever'sneighborhood's Avatar
Default on/off fan switch
does anyone know to make a on/off switch
if you do can you share that information please
i tried searching and i found some things i wasnt lookin for =[
Old Mar 25, 2009 | 09:34 PM
pandarex's Avatar
Default Re: on/off fan switch
you need
-relay, try to get bosch or similar cause there easy
-switch
-good amount of wiring
-solder, or butt connectors, and tape and all that connectin wire stuff
-basic understanding of relays, and all that
you want to mount the relay near the fan. run 12v power to both the 30 and 85 of the relay. run one wire from 86 to the cabin and connect to one side of the switch, the other side connect to ground. run a wire off 87 and connect it to your fan. the other wire on your fan connect to ground. make sure you wired it to spin the correct way, it can spin both ways but cools effectively one way. someone chime in if there is anything else i missed out on.
also try goggle
http://www.classictruckshop.com/club...osch/relay.htm
http://www.bcae1.com/relays.htm
Old Mar 25, 2009 | 09:49 PM
radex7's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-can-i-hardwire-my-fan-always-run-2530498/
Old Mar 26, 2009 | 07:46 PM
thanks =]
thats good info
Dee9222
Mar 18, 2014 01:34 AM
blasterman87
Jan 14, 2010 06:49 PM
4DRmafia
10
Jun 20, 2004 10:49 PM
st0nedstoopid
Jul 11, 2003 12:19 AM
