Tps help
i have a b16 in my 91 sedan and i need to know if theres a way to check or calibrate my tps. its not throwing any codes but when im at a crusing speed it cuts back but if i hit the gas it accelerates fine, but when i get to a constant speed it starts cutting back again. it could possibly be something else any suggestions would be welcome.
Using a multimeter check for voltage on the middle (red) wire, you should have .5v. Use a t-25 torx to loosen the sensor, turn until you see .5v , tighten the sensor and recheck your readings. If that doesent help, adjust your valves and make sure you ignition system is perfect (good cap, rotor, plugs wires, ignition timing)
B16acivicsedan91
Feb 28, 2008 09:39 AM
