OBD2 B20 into OBD1 RS?
Old Mar 25, 2009 | 04:32 PM
EKris's Avatar
Default OBD2 B20 into OBD1 RS?
I will be putting a B20 into my DC Integra here shortly, and have never put an OBD2 motor into an OBD1 car, what is needed to be done? Are there any real complications that I should look for?
Old Mar 25, 2009 | 05:15 PM
whitengolddc2's Avatar
Default Re: OBD2 B20 into OBD1 RS?
just get a obd2 to obd1 jumper (rywire or anywhere else). i belive you will need to use the obd2 engine harness. that should be it becuase it is a b series motor in a b series car.
Old Mar 25, 2009 | 06:25 PM
2ndgentegracer's Avatar
All you need to do is put your obd1 distributor, intake manifold, and exhuast manifold onto the b20. No need to get a jumper harness, just reuse your obd1 engine harness. Its a pretty straight forward swap really.
Old Mar 25, 2009 | 10:45 PM
1992db2's Avatar
yea, convert your motor to OBD1, not your car to OBD2
Old Mar 25, 2009 | 10:57 PM
V8 Eater's Avatar
the last two are the right answers, all you need to do is take your dizzy thats on the ls and swap it onto the b20,then take the exhaust and intake manifold off your ls and swap them aswell, this wayy all hoses,wires are exactly the same as they used to be letting you use the original ls ecu(the ls exhaust manifold is just a better flower thats all) however remember you are bumping the original compression from 9.2 to 9.6 and the dissplacement aswell and you probably have bolt-ons so a tune would yield a healthier,stronger outcome! remember that you dont need to wire new sensors that come with the obd2 b20 such as knock sensor and such, do not worry you will not pull a cel because of this its fine since the original ecu never had a knock sensor to be wired. and is this a jdm b20? there is some step you need to take when dumping in a jdm b20 into an usdm ls, I believe it was about some crank position or fluctuation sensor or something but if the b20 is usdm dont worry!
Old Mar 26, 2009 | 12:12 PM
EKris's Avatar
Well, I am not swapping from an LS to a B20. I have a high compression b16 that I am trading a buddy for his built B20. ANd I plan on boosting the B20. I was planning on boosting the b16 with methanol on really low boost, but I just don't feel like risking it.
I believe my buddy told me he wired everything through the dizzy? I am guessing that he just used an OBD1 dizzy for the motor.
Old Mar 26, 2009 | 01:22 PM
DC206R's Avatar
yeah, i'm going to swap a OBD2 Ls into my OBD1 car soon and i'm pretty sure its jst the exhaust, intake manifold, fuel rail, injectors ETC, and Dizzy. one question though, are all b-series alternators the same? automatic /manual? obd1/obd2?
Old Mar 26, 2009 | 01:28 PM
95LS1t's Avatar
yes^
and u need the intake manifold from a b18b, the b20 one will not fit under the hood
Old Mar 26, 2009 | 01:32 PM
95LS1t's Avatar
b18b compression is 9:7, 98+ for b20's are 9:6, and 96-97' are 9:2
but yeah, u need a b18b obd1 intake mani, dizzy, n wiring harness, along with the ecu from a obd1 LS. it's cake
Old Mar 26, 2009 | 10:48 PM
V8 Eater's Avatar
sorry my friend but you got most of that wrong, dont trust where ever you got that info from. the b18b is infact 9.2, and the 96-98 b20b is 8.8 and finally the 99-01 b20z is 9.6. it is cake though!
Old Mar 28, 2009 | 07:18 PM
EKris's Avatar
So wiring harness, ECU, intake mani, dizzy, is what is needed? Actually thinkin about this, it won't be too bad because I am getting the swap off a buddy who has it in an OBD1 car.
Old Jul 11, 2009 | 02:14 AM
eh2_erik's Avatar
nice, this thread was a big help!
hondaclown
Jul 7, 2011 05:12 PM
jlowellintegra
Sep 3, 2010 07:34 AM
Chilloutdamn
May 13, 2009 05:58 PM
BoltonGSR
Feb 19, 2007 01:35 PM
integranator
Dec 21, 2002 07:16 PM
