DIY Short Shifter
Sorry cant find the DIY thread, but heres a DIY for you guys
Mines a little different than those other short shifter DIY where you have to drill your shiftknob. Instead of drilling my shiftknob, I decided to sand down my shifter.
1. removed the shifter
Theres a DIY on how to remove the center console and the shifter somewhere on here
2. Now you need some sort of a grinder, i used something like this
Now grind it just enough so the shift **** will be able to go all the way down, I stopped at the little things sticking out on the sides of the shifter
3. Now it should look liket his when your done
I painted it black
4. Make sure the shift **** fits on and stops turning at the point where the numbers on the **** is facing you, or else your gonna have to do a little more grinding.
5. put everything back
The height where the shift **** sits is adjustable.
When the shift **** is all the way down it feels more accurate and precise and the throw is shorter but shifting requires a little more thrust than when the shift **** is sitting up high. When the shift **** is up high, shifting is very light and the throw is longer
I painted it black
yikes.
why not just get a short shifter? its easy enough as it is on our cars comparing to an integra and mk4 gti ive done it on. plus ill be kinda scared that itll snap off.
nice try though props for the effort. but i think this DIY could end in disaster with a kid whos first car is an 8th gen and is broke but is eager to mod. i used to be one, well now i just have a little bit more money lol
Now I was thinking of doing something like this. Not because I thought it would shorten the throw. I already have the comptech short shifter. I just wanted to do it because i thought it would look a little more like the s2k set up. But that grinder scares the crap out of me! Looks good though!
