anybody know why my EF takes so long to start?
Old Mar 25, 2009 | 12:47 PM
LSXFEIND's Avatar
Default anybody know why my EF takes so long to start?
hey everybody i have a EF with a mini me swap that runs GREAT besides its noisy throw out bearing lol!, but heres my problem in the morning when i try to start my car it takes about 5 or 6 trys to actually start and when it does it runs like crap till it warms up then after a min or so it runs perfect, after that once ive started it the first time...all day it starts right up but im just confused maybe its the ECU gettting Confused dont know??? but any help would be great thanks!
Old Mar 25, 2009 | 01:23 PM
4drEF's Avatar
Keyboard Humorist
Default Re: anybody know why my EF takes so long to start?
Are you getting any other symptoms such as a Check Engine Light that is on?
Old Mar 25, 2009 | 02:15 PM
jhammond_82's Avatar
Reject Papi
dirty fuel? plugs fouled? wires need replacing? you said it's hard to start, basically when cold in the morning. i would guess that maybe the fuel filter needs replaced. when was the last time you did a complete tune up?
Old Mar 25, 2009 | 02:30 PM
BAL1ST1KREX925's Avatar
Used to have the same problem I change my main relay and fuel pump. After that my car was running like a champ so i suggest check you those two things.
Old Mar 25, 2009 | 02:43 PM
Reject Papi
possibly a fuel pump yes. but a man relay? from my experience, they show no signs of going bad, they just **** all at once. its like a fuse almost. no signs of future blowing, it just all of a sudden goes.
Old Mar 25, 2009 | 04:13 PM
Cole89ef's Avatar
I was having the same problem with my ZC, but I just threw a b16a in and it all went away. But I am curious to find out what was actually causing it, I was thinking it had something to do with the spark timing being a little off.
Old Mar 28, 2009 | 06:25 AM
staatsper4mance's Avatar
its your thermo time switch located under the dizzy u have two plug that go to sensors ....its the one with two wires on it........the one with the single wire is your temp guage and the one with two is thermo time switch ...........change the switch........problem solved.....................mine did the same thing
Old Mar 28, 2009 | 10:41 AM
Ahknodd's Avatar
Interesting. Do it and tell us if that fixes it. I guess it makes sense. It probably failed and is stuck saying the motor is hot so the ecu doesn't supply enough fuel to start up the bone cold motor. After the motor heats up the ecu is giving the motor the right amount of fuel and it'll start and run fine. Sweet.
Luke 91 ef
Jan 24, 2013 10:40 AM
88EFsedan2
14
Feb 11, 2012 09:17 PM
turbob16ferio
Feb 4, 2011 10:35 PM
Stephen90Si
10
Aug 16, 2009 10:56 AM
GasDreamz
16
May 6, 2009 05:21 PM
