shaving engine bay? (searched)
Old Mar 25, 2009 | 11:38 AM
texaszcrx's Avatar
Default shaving engine bay? (searched)
ok im just wandering if it would be at all possible to shave an engine bay by fiberglassing it rather that welding. i have sum experience with fiber glass, but none welding, also you could more easily mold things in the bay using fiberglass i would think. i searched and didn't find much on using fiberglass on the bay. most people weld the seams and holes while others use bondo (which from my reading, isn't recommended) thanx for any imput.
Old Mar 25, 2009 | 11:42 AM
toyomatt84's Avatar
Sanji
Default Re: shaving engine bay? (searched)
https://honda-tech.com/forums/honda-acura-28/shaved-tucked-customized-engine-bays-pics-theory-discussion-1693934/
You searched?
Old Mar 25, 2009 | 12:01 PM
texaszcrx's Avatar
that was the first post i viewed, however there isn't much info on using fiberglass to fill the seams and holes.
Old Mar 25, 2009 | 12:05 PM
toyomatt84's Avatar
Sanji
That should be a clue, really. If it's not common practice, then there's probably a reason for it.
Old Mar 25, 2009 | 12:22 PM
texaszcrx's Avatar
just because most do something one way doesn't mean that there are not other methods that may work. have you experienced using fiberglass in the manner im asking about or know of anyone that has? if so i would appreciate your input but if not the i would appreciate it if you'd not comment.
Old Mar 25, 2009 | 01:06 PM
lilo_goki's Avatar
tried it out and tell us how long it last, i'm interested in it as well as the bondo.
Old Mar 25, 2009 | 01:23 PM
phunhaus's Avatar
You might get more responses by posting this question in that thread . . . since it's for pics, theories and discussion.
Old Mar 25, 2009 | 01:36 PM
EFinawesomeman's Avatar
Fiberglass to shave a bay?
Old Mar 25, 2009 | 02:11 PM
texaszcrx's Avatar
i wouldn't try to only use bondo, but using alittle as a filler for seams and holes and the laying up multiple plies and feathering them out might work. idk. i think when i get to shaving the bay im gonna try fiberglassing it rather than welding it.
Old Mar 25, 2009 | 02:53 PM
toyomatt84's Avatar
Sanji
Considering my friend used fiberglass to sort of "remedy" his engine bay, I guess I do have some experience. It won't look terrible, but it will be noticeably different than if you were to use a welder and do it the proper way.
MarkCayabyab
Northern California
Nov 22, 2016 03:27 PM
CTCD5
Sep 19, 2013 03:19 AM
dev203d
Welding / Fabrication
Nov 18, 2010 02:37 PM
dc4teg95
Paint and Body
10
Nov 23, 2009 12:59 PM
DailyBlown
Oct 13, 2004 08:08 AM
