what size gsr bearings???
Old Mar 25, 2009 | 08:06 AM
91(si)hatchey's Avatar
Default what size gsr bearings???
hey im ordering some new bearings for my gsr. i measured my crank and it came out to 44.90mm for rods and 54.97 for crank journals. hopefully this helps, im going acl bearings btw. should i go standard or o.s.
Old Mar 25, 2009 | 08:17 AM
lsvtecwill's Avatar
Default Re: what size gsr bearings???
It's always been worth it to me to pay a machine shop to do bearings. (NOT something you wanna mess up)
my .02
Old Mar 25, 2009 | 08:39 AM
Fink29's Avatar
Answer these questions and maybe someone will be able to assist you easier.
What rods are you using? Stock or aftermarket?
What are your rod big end measurements?
What are your main bearing tunnel measurements?
You only have half of the measurements you need.
Old Mar 25, 2009 | 09:54 AM
doing the bearings isn't hard at all. oem gsr rods. ill measure that stuff tonight
Old Mar 25, 2009 | 06:34 PM
Fink29's Avatar
If you are using the stock crank and rods do the following.
Take down your bearing codes from your crank. Should be letters or bars ie. bbbbb,cbcbc or l, ll, ll and ect. ( If you sit the crank in front of you with the oil pump side on your left hand side the code will be on the left side of your counter weights.)
After that take your bearing codes from your rods. should be numbers 1234.
When you have the two match them together and look to your honda manual. If the manual says that you can run green bearings then you'll be able to use the standard ACLs. If not run the color bearings it says in the manual.
Old Mar 25, 2009 | 06:35 PM
Fink29's Avatar
No disrespect but If you say bearings are easy to do how come you are posting for help to do them?
Old Mar 25, 2009 | 07:25 PM
ruffrhyder's Avatar
I just had to post this.
https://honda-tech.com/forums/forced-induction-16/honda-bearing-color-thickness-chart-everyone-who-loves-using-oem-bearings-715505/
Old Mar 27, 2009 | 12:52 PM
alright well i know how to install them just never had to buy them. i measured the clearances without bearings for the crank journals and rod journals.
crank main journals
.163 .164 .163 .163 .163
rod journals
.125 .124 .124 .125
the numbers on the crank starting with oil pump side first
rod 1-c4 on one side and 3 on other side
rod 2-c on one side and 3 on other side
rod 3- d on one side and 4 on other side
rod 4- c on one side and 3 on other side
i did my best to use that website to figure out what bearings will fit, but it seems like this crank was grinded down some so the bearings definitely need to be oversized, the company is offering standard, .25 and .5 over. its pretty close to needing .5 over. what do you guys think
Old Mar 27, 2009 | 06:00 PM
ruffrhyder's Avatar
You're doing it wrong.
http://www.evans-tuning.com/videotec...ine_build.html
Old Mar 28, 2009 | 02:31 PM
those are sick videos. ya i was doing the calculations right. btw. when acl says they have std. .25 and .5 over. what size are they basing it off of.
Old Mar 30, 2009 | 02:24 PM
alright well i got all my measurements done.
main journals are 2.328"
crank journals are 2.1638"
crank rod journals 1.7693"
rod bore 1.895"
im gunna re measure the main journal bore size tomorrow cuz if my calculations are right .25 o.s. will be too thick of a bearing by like .05. i know all my other measurements are right besides the main journal, it might b a lil bigger, which would give me more room for .25 o.s.
Old Mar 30, 2009 | 07:23 PM
ruffrhyder's Avatar
rod bore 1.895"
Post the bearing codes on the bottom of the block and the codes on each rod.
Old Apr 1, 2009 | 08:55 PM
so i finally figured it all out. there were no numbers on the block like shown in that video. i didn't have my camera so i didn't take pictures but trust me. i got all my measurements together and finally found the stock specs on alldata and figured out the bearings will be standard size. thanks for the help
Old Apr 27, 2009 | 11:03 PM
oyy0's Avatar
there are always letters on the block, you need to know those letters.
Old Apr 28, 2009 | 07:23 AM
ruffrhyder's Avatar
There aren't NUMBERS on the Block, there are Letters. Numbers are on the crank and rods.
Old Apr 28, 2009 | 07:35 AM
mar778c's Avatar
Community Builder
Community Influencer
This is going to end bad unless the OP takes the crank, block, and rods to a machinist with the proper tools and accuracy to make the measurements.
OP, what clearances are you shooting for?
mayfly
May 17, 2012 02:45 PM
H9Omega
Mar 18, 2007 08:51 AM
OrangeBoost
Oct 19, 2005 06:14 AM
94civickid
Mar 15, 2005 02:10 PM
lsvtec hatch05
22
Dec 4, 2003 09:51 AM
