Standard B16 Fuel pump flow rate.
Old Mar 25, 2009 | 08:00 AM
EddieCRX's Avatar
Default Standard B16 Fuel pump flow rate.
What does the standard B16 Honda fuel pump flow, not talking what power it supports just flow.
I understand running a direct power feed to the battery (relay in line) will aid efficiency a little, Honda have over engineered everything else so what about the fuel pump.
I have tried to find the answer but to no avail, anyone?
Old Mar 25, 2009 | 08:04 AM
Turbo-LS's Avatar
Default Re: Standard B16 Fuel pump flow rate.
not sure on the flwo rate but generally a stock fuel pump is good for about 8 psi of boost with moderate turbo. They just dont cut it when it comes to flow. Now if your trying to do somehting like leave the stock fuel pump in place and then run an inline walbro or bosch 044 then that will work jjust fine and will give a little help to the inline pump
Old Mar 25, 2009 | 09:06 AM
EddieCRX's Avatar
I’m not implying I’m going to try this but it certainly makes interesting reading
http://www.hondatuningmagazine.com/f...ems/index.html
Again, not disputing your real world experience but it would seem quite a few people have run the standard fuel pump beyond 8psi with a reasonable size turbo and experienced no problems.
Me personally, I just not sure it’s worth the risk for the price of a after market pump but I’m curious to know what the OE pump actually flows.
Old Mar 25, 2009 | 12:22 PM
Turbo-LS's Avatar
Originally Posted by EddieCRX
Me personally, I just not sure it’s worth the risk for the price of a after market pump .
you answered your own question right there
Vegas H22Prelude Si
Oct 13, 2008 08:10 AM
viet_boi_racin
Feb 3, 2008 09:34 AM
VspecSiR
May 17, 2004 04:37 AM
Screamer
Jun 18, 2003 09:17 AM
