What coolant? 05 S2K
Curious what coolant you guys are running in your car. I upgraded radiators and will need to refill the system.
Is it the regular green stuff?
Prestone 50/50 for example?
I'm **** and only use OEM....it's only a few bucks more. The new Honda fluid is type 2 and its blue. Premixed already and from what I've read you can mix it with the old green stuff, but I'd jsut do a full flush.
I use whatever is the cheapest, typically "store brand" then cut it 50/50 myself. You get twice a much coolant for the same price as buying the premix ****. Then add a bottle of water wetter to it. That's my formula....haha
Cool Cool Island Breezes. BOY-EE
Yeah, it's really rare. They don't sell it at every grocery store in the whole world. It's expensive as well. This is an excellent excuse.
There is a drain plug for the block. It's underneath the car. It's a 19mm. Look by the header for a drain plug looking thing on the block. You'll probably want a replacement gasket...and it calls for resealing it with non hardening sealant. It's in the owner's manual. With pictures...
Buy enough coolant to make around 2 gallons. It's 1 gallon and some change, IIRC. It's in the owner's manual also.
BTW, I just use the OEM stuff. I get it for free or cheap...and my friend who is a tech at Honda tells me that it's better for the water pumps. But it could all be mumbo jumbo.
Yea, I had some distlilled for the longest time, finally ran out. I only use a small amount of actual "anti-freeze" as compared to straight water.
dth0ng69
10
Jul 8, 2009 07:49 AM
Duck Sauce
Nov 23, 2001 08:49 AM
