95 H22 Del Sol Engine trouble please help
Old Mar 24, 2009 | 10:04 PM
95dsfreakjason's Avatar
Default 95 H22 Del Sol Engine trouble please help
I have a 95 del sol with an H22 swap P28 ecu with hondata at times when im driving my speedometer will drop to 0 and it wont let me rev past 4500 rpms. But while the speedometer is working i can rev to 7800. Can anyone tell me what is wrong.
Old Mar 24, 2009 | 10:11 PM
JarvisW's Avatar
Sol to Sol
Default Re: 95 H22 Del Sol Engine trouble please help
Just a shot in the dark, but poor ground? Check the engine, and the plug behind the gauge cluster. (its a single wire that grounds back there, not the cluster harness (tho it comes off there))
Old Mar 25, 2009 | 08:42 AM
i was thinking a bad ground but a friend also told me it might be a bad speed sensor off the tranny
Old May 11, 2009 | 09:12 PM
still no fix i replaced tranny speed sensor and vtec solenoid is good please help.
Old May 11, 2009 | 09:23 PM
Former User's Avatar
Is the CEL ON? Are you retrieving code 17 and possibly other codes?
Start by checking the VSS connector and wires.
Old Jan 17, 2010 | 01:48 PM
no CEL please help
delsol909
18
Sep 2, 2023 07:18 AM
95dsfreakjason
Jan 31, 2010 03:34 PM
beaver619
Mar 27, 2008 03:18 PM
