choppy take off.?.
Old Mar 24, 2009 | 06:09 PM
92d16z6's Avatar
Default choppy take off.?.
This may be hard to explain. When I take off from a stop, just enough to let out the clutch all the way then put it to the floor it will lightly chug. Kinda like if you were to let off the gas and reapply it quickly. It has a complete tune up within the past 5000 miles. I also aquired a new oil leak right by the Vtec plug. I cannot see exactly where it is but around that area. Is this a common spot for this to happen?
92 Civic EX Vtec. Manual
Old Mar 24, 2009 | 06:44 PM
93egSLEEPER's Avatar
Default Re: choppy take off.?.
sounds like you have clutch chatter, that is the "chugging problem" the vtec solenoids are notorious for leaking in hondas. more then often they do
Old Mar 24, 2009 | 07:40 PM
92d16z6's Avatar
IT seems fine after about 2500rpms but anything lower i get it. Bad clutch?
The Vtec solenoid, should i Just replace it. And stop the leak?
Old Mar 24, 2009 | 07:47 PM
newtron63h's Avatar
sounds like you are lugging the engine, hondas dont have anything down low.
Old Mar 25, 2009 | 05:17 PM
92d16z6's Avatar
Indeed, your right about that. But from time to time it seems to act as if has lost power also. Peppy one minute, next lacking. Ohh also, sometimes when i start it It act's like the timing needs to be advanced. Very sluggish when started. But that happens only on occasions.
Old Mar 25, 2009 | 05:37 PM
newtron63h's Avatar
sounds like a good solid tuneup is needed
Old Mar 25, 2009 | 06:16 PM
92d16z6's Avatar
I did everything 5000 miles ago. Plugs, wires, cap, rotor, PCV, air filter, fuel filter, along with new axles, and bearings.
Old Mar 25, 2009 | 06:35 PM
newtron63h's Avatar
hmmmmmmmm, very interesting. i mean it definitely could be a clutch problem, does the chugging happen all the way through the rpm range? or just down low? does it gett better, does it go away completely, does it do it everytime?
Old Mar 26, 2009 | 04:36 AM
92d16z6's Avatar
Only under 2500rpms, It completely goes away after that. It seems like a fuel issue or spark/timing. Can the engine be shot with a timing light?
Old Mar 26, 2009 | 04:48 AM
dividedas1's Avatar
it sure can (the timing light). mine was doing this too when i backed off my timing. when i advanced it again after winter it was fine. meh i need a tune up. i actually think my distributor is going going gone.
Old Mar 26, 2009 | 09:51 PM
92d16z6's Avatar
I guess Ill get the timeing light out. Also seems not that the vtec is not kicking in.
Chrizcrozz
Aug 31, 2011 10:11 AM
Markov
Oct 28, 2005 10:44 PM
spoon-itr
Jul 9, 2004 04:57 PM
MortalistiCivic
Jul 23, 2001 09:14 PM
