o crap i broke it...
Old Mar 24, 2009 | 04:59 PM
JDMgunmetalCRX's Avatar
Default o crap i broke it...
ok i broke my brakes...
i took out the brake master cylender so i could replace the alternator...and btw i used the d16 alternator on my b16 and it bolted up perfectly...one bolt missing but it fit!
anyway my problem now is my brakes wont work.
if i step into the brake it just goes in like butter...no stopping.
how do i fix it?
Old Mar 24, 2009 | 05:03 PM
91crix's Avatar
Default Re: o crap i broke it...
you need to bleed your brakes since you took off your master cylinder
Old Mar 24, 2009 | 05:16 PM
can u give me a step by step direction on how to do that?
how much brake fluid am i gonna need?
Old Mar 24, 2009 | 05:24 PM
KoDKingVegeta's Avatar
Anyways, its easy to bleed the brakes. Start by filling your master cylender up. Second find someone to help you, third, have your helper pump the brake pedal a few times, and have him hold it. Well the helper is holding the brake pedal, go to the rear passenger side, you will see eather a red/blue or black rupper cap. Take that off, you will see that it is a nipple, find the wrench that fits it, (I think its a size 10 can't remember). Just light crack the screw lose, brake fluid will start to come out (the more you open it the faster it comes out, so open it very slowly). lave it open for just a few seconds or until fluid starts coming out all the time (the first few times you do it, it might spit, thats good your getting all the air out of your brakes). Keep pumping the brakes and cracking it lose till fluid comes out all the time. Then go to the rear drivers side, do the same. Then go to the front passenger side, turn the well all the way right, so you can get to the nipple, repeat on the drivers side. Then refill your master cylender. And test your brakes out.
Old Mar 24, 2009 | 05:27 PM
awesome guys. thank u so much...
ive been trying to get my frekkin car started all day...i even took out the starter. turns out the alternator wasnt letting the battery charge up so it was running off the battery.
replaced that and now i gotta do my brakes...
but thanks everyone i appreciate it.
low91rex's Avatar
You don't have to take the master cylinder to replace your alternator.
Old Mar 24, 2009 | 05:29 PM
The nipple is on the back of the hub for the rears, and the nipple is on the back of the calibers for the front. You might have to jack your car up, depends on how low it sits.
Old Mar 24, 2009 | 06:08 PM
well i couldnt find ANY way for that B series alternator to get out....i had a upper strut bar so that made things more difficult. trust me there was no room. i even got under my car and removed the oil filter...(got me a new oil change) and it still wouldnt come out...i had to.
can i bleed the rear brakes? their drum brakes but idk if they have a nipple for me to bleed it
Old Mar 24, 2009 | 06:24 PM
The nipple is on the back of the drum, Im sorry.
This is NOT the picture for the Honda. But this is what the nipple looks like on the disk.
And the rear,
Hope this helps
Old Mar 24, 2009 | 07:25 PM
alright thanks man.
u guys have been very helpful.
now my brakes feel just as they used to be!
Old Mar 24, 2009 | 08:34 PM
Im glad you figured it out, but I did forget to say, everytime you crack the nipple lose, the brakes will go right to the floor. Then well your partner is holding the brakes to the floor. You tighten the screw, then have him pump them again, and open the nipple. And just keep doing that over and over to all of them untill your brakes feel good.
Old Mar 24, 2009 | 08:43 PM
mitsubishiv5's Avatar
HAHAHA. nice. ya bleed your brakes start from farthest from the brake master cylinder. which should be passenger side drum, then drivers side drum, passenger side front caliper, drivers side caliper. pump the break atleast 3 time to insure the air is shot out, hold the breaks down and close the "nipple"HAHA. then pump and pressurize and repeat till no air bubbles are visible. but otherwise everytime you take release a part from the braking system be sure to release all air from the system! always have an extra bottle of dot 3 fluid with you while doing this
Old Mar 24, 2009 | 08:46 PM
always use a vise grip or 10mm wrench for this or you will strip the bolt! 10mm please
Old Mar 24, 2009 | 09:15 PM
gator88's Avatar
vise grip? thats ****ing retarded. get a 6 point box end 10mm and dont **** **** up being a retard. holy hell thats just stupid to even mention that.
Old Mar 24, 2009 | 09:32 PM
*ctrlaltdel's Avatar
haha "git r done"
Old Mar 24, 2009 | 09:50 PM
man wtf do you know?! i said or a 10mm wrench. ive tried that **** as well and they strip eventually. wtf can you expect from a 18 year old car? like someone will have the money to even buy that stupid tool. and when your **** is done no matter how its done it wont need to be touched. the end
Old Mar 24, 2009 | 09:51 PM
stupid ***
Old Mar 24, 2009 | 09:52 PM
ill go over to your avatar and poke a needle through it to make that **** pop.
Old Mar 24, 2009 | 09:54 PM
a six point 10mm? everyone in this forum should own one.
Old Mar 24, 2009 | 09:58 PM
oh i meant to talk about the open ended box wrench to take off the brake lines from the drum/rotor itself. they always strip. anyways i win! level up
Old Mar 24, 2009 | 10:46 PM
hatchet_honda's Avatar
your calling a 10mm box end wrench a stoopid tool? i believe your the stoopid tool my friend..i have never had to use effin vise grips to remove a bleeder screw
Old Mar 24, 2009 | 10:50 PM
it woulda been wayyy easier to remove the drivers side cv axle then drop the alternator out that way then tryin to take it out the top by removing the master...never heard of goin thru that much trouble
Old Mar 25, 2009 | 09:55 AM
gator88's Avatar
Alighty bud, try talkin a little more ****. We are obviously talking about the bleeder nipple, not the brake line itself. You mention vise grips when we are talking about something easily acessible with a standard wrench, so I say how retarded that is... As for the brake line yes, that is more of a specialty tool and sometime vise grips are needed as an open ended wrench will just strip it if you dont have a wrench to borrow or dont want to spend the few bucks. Got that. Your a ****in tool, "I win, level up" Get a ****in life and quit talkin smack over the internet. Your gonna pop my avatar, how cute, this is 3rd, or 4th grade?
If you were intelligent at all, you would have simply stated you were talking about the brake line and everyone would of understood. Whatever, talk some more ****, this is retarded. Ill let you win, own me, whatever. Have a good one. Cheers!
Old Mar 25, 2009 | 10:02 AM
LOL..............oops :p Anyways the tool is called a brake line wrench. They don't cost very much. But now that its over with, lets all get along. :p
Old Mar 25, 2009 | 10:15 AM
LOL i love how ppl spell common part names wrong...
breaks
blead
disk
retart...thats not a car part obviously but its still friggin highlarious!
