Factory Timing Belt Only?
Old Aug 13, 2002 | 01:38 PM
3rdGteg's Avatar
Default Factory Timing Belt Only?
I'm planning to change my timing belt within the next few days and I'm just curious if anyone else have tried any other aftermarket brand besides the one from the dealer. I'm told even the aftermarket ones are as accurate as the factory ones--is this correct? Just the quality, maybe strength-wise is not as good. But I just want to make sure it'll do the job that's all. I had bought one from PepBoys for like 64 bucks and debating whether to install it or get another one from the dealer. I just need some reassurements that maybe this belt I already have will work the same as the factory one I guess. Any comment will be appreciated, thanks.
Old Aug 13, 2002 | 02:20 PM
b18bvtec4drteg's Avatar
Default Re: Factory Timing Belt Only? (3rdGteg)
well when it comes to timing belts, master cylinders and important stuff I always go factory parts. Dont have to worry about it. Make sure u get a water pump and belt tensioner while ur at it.
Old Aug 13, 2002 | 02:51 PM
3rdGteg's Avatar
Default Re: Factory Timing Belt Only? (b18bvtec4drteg)
So my pepboys belt is not good enough? Also, I only need to replace the water pump and belt tensioner if it's messed up right? Thanks for any reply.
Old Aug 13, 2002 | 04:08 PM
tinkerbell's Avatar
if it aint broke - dont fix it...
Old Aug 13, 2002 | 05:31 PM
AzG35's Avatar
Default Re: Factory Timing Belt Only? (tinkerbell)
It depends how many miles are on the water pump. If there are more than 65k I would do it anyway. Its easier since the pump is right where you will be working and its a pain to have to take everything apart again later on. Do everything in one shot and don't worry about it later
Old Aug 13, 2002 | 05:32 PM
minime's Avatar
go factory with the t belt and water pump.
Old Aug 13, 2002 | 10:53 PM
3rdGteg's Avatar
Default Re: Factory Timing Belt Only? (minime)
I can't really return my timing belt since I've bought it 5-6 months ago and lost the receipt; I'm gonna have to use it unless I can sell it which I truly doubt. Especially when everyone wants the factory t-belt anyway. The factory water pump is like another 50 bucks that I don't have. I'll just change it later when it goes bad I guess. But does anyone know how to inspect the water pump to see if it's bad?
Old Aug 13, 2002 | 10:56 PM
tinkerbell's Avatar
to take it off and inspect for wear/damage, it has 5 bolts i think,
but you WILL need a new seal when re-fitting hte pump.
dont forget the Hondabond!
t..
Old Aug 13, 2002 | 11:00 PM
3rdGteg's Avatar
Thanks tinkerbell.......I hope I can get that damn crankshaft bolt off this time-- I bought a 200 impact gun just for that one bolt.
Old Aug 13, 2002 | 11:32 PM
tonyxcom's Avatar
You dont need hondabond on the waterpump. If you replace the 2 dollar gasket/oring then you surely dont need hondabond.
Old Aug 16, 2002 | 11:40 AM
93CivicSI's Avatar
Go with Factory timing belt water pump tensioner etc...
Old Aug 18, 2002 | 01:37 PM
ShootingStar's Avatar
I had a non-OEM water pump self-destruct and take out a non-OEM timing belt at 27,000 miles on my '89 Si. No damage to the engine (whew!) but nothing but OEM for critical parts from now on!
Old Aug 18, 2002 | 02:46 PM
mugenracer's Avatar
Default Re: Factory Timing Belt Only? (ShootingStar)
i replaced my water pump with a QH non genuine one, i compared the old genuine one with the new one and they're exactly the same, the QH one was made in japan and i wouldnt be surprised if they make pumps for honda. But i always use a genuine timing belt, even though i've been told bosch belts are as good if not better than genuine, plus the OE belt was only $10 dearer than the bosch one
Old Aug 18, 2002 | 03:32 PM
3rdGteg's Avatar
Default Re: Factory Timing Belt Only? (mugenracer)
But I already have the pep boys one and I think it's that bosch belt anyways, so it should be as good as the oem one right? I'm thinking about just getting an oem wp to go with this non oem belt. But u guys are kinda scaring me about these non oem belts snapping and stuff. I'd really like to get a factory belt, but then I would have to just throw this one away?
Old Aug 18, 2002 | 03:40 PM
GruvyTune's Avatar
New User
i got mine from autozone and its a goodyear type. i researched it and all sources say as good or better than stock!
Is it absolutely necessary to replace the tensioner at a certain mileage? I hear different things about that. i didn't replace mine on my rebuild. Has 77K miles on the original engine. tensioner seems to still be ok.
what are signs of age on them?
honda2112
Apr 15, 2010 05:10 AM
chahsiubow
Dec 14, 2007 10:01 PM
tomcool
May 14, 2007 08:40 PM
honda94accord
Apr 10, 2007 05:39 AM
