Retaining Power Steering and A/c after swap?
I am swapping a b18c1 into a 2000 civic dx hatchback. I wanted to know what brackets I would need to retain A/C and Power steering. I have heard of using CRV brackets and also Si brackets but I want to find out which ones, so I can gather all the parts I will need.
i read up on the faq's and from my understanding I can use the obd2 gsr p/s pump and stock ek lines. i also found that i can use the gsr lower and upper brackets. Im still unsure of the bracket for the a/c but I believe i can use the b16a2 bracket
Use any B-series VTEC P/S brackets along with a '99-'00 Si P/S pump or '98 OBDII GSR pump to retain your D-series lines. Use a CRV A/C bracket to keep on using your D-series compressor.
NOTE: There are two different P/S pumps, make sure you compare the pump before you buy. I don't think PR3/P30 A/C bracket will work, double check that before you buy it.
98silverbullets
Honda CR-V & Element
Apr 27, 2015 07:06 PM
DawgC2
Feb 12, 2013 12:34 PM
raverx3m
Dec 27, 2011 04:56 AM
