Need quick help regarding window regulator
Old Mar 24, 2009 | 10:45 AM
Backk InTheDA's Avatar
I hate everything
Default Need quick help regarding window regulator
I am replacing the window regulator on my 1990 Accord and I am having trouble removing the front driver side door panel. I have all the screws removed but I can't seem to figure out how to remove the piece that holds the power lock and door handle.
It seems like there is a clip somewhere but can't seem to find it. Can anyone help?
Thanks,
Old Mar 24, 2009 | 11:04 AM
redbull-1's Avatar
Default Re: Need quick help regarding window regulator
On most Hondas, there should be a purple color plastic clip. The clip should rotate clockwise to come off the rod. Use a small flat-tip screwdriver or something to push it carefully off the rod.
Old Mar 24, 2009 | 11:05 AM
nwf_snake's Avatar
Push forward, then pull, then disconnect the lock rod.
Old Mar 24, 2009 | 01:09 PM
I hate everything
Got the broken regulator out, but the new one doesn't seem to line up with the screw holes. It is identical to the old one, but it doesn't line up. Can anyone help?
Old Mar 24, 2009 | 01:14 PM
I hate everything
The screw holes don't line up for whats on the door.
Old Mar 24, 2009 | 01:56 PM
dtapia's Avatar
try to hook up the motor and collapse the regulator some almost flat and see if it will line up.
tallypbplayer
Mar 17, 2010 09:53 PM
Cnu182
Jul 24, 2006 11:48 AM
RedRex8
May 3, 2003 12:40 PM
cd5_2NR
Mar 12, 2003 12:27 AM
DRAG1320ciVHBKsi
Nov 29, 2002 09:50 AM
