low idle when stopped
Old Mar 24, 2009 | 08:57 AM
freakasis's Avatar
Default low idle when stopped
95 DX 5 speed stock. when im coasting in neutral the idle is perfect at like 800 but when im stopped (whether im on the brake or not or on the clutch or not) the idle drops to almost zero and it start vibrating. things i have tried: dizzy, plugs, wires, iacv, and air filter. and it doesnt really matter how fast im coastin, it can be 5 or 65, the idle is still perfect. any idea what the problem is?
Old Mar 24, 2009 | 12:49 PM
jmflyd's Avatar
Default Re: low idle when stopped
no but iv been having the same problem the last two days but i stall out once in a while
Old Mar 24, 2009 | 01:36 PM
Former User's Avatar
What have you done to the IACV? It's a prime suspect.
Is the CEL ON?
Also check whether the PCV valve or hose or breather hose is clogged.
Old Mar 24, 2009 | 02:58 PM
freakasis's Avatar
i cleaned the IACV, i havent replaced it yet. no CELs and i will check the pcv valve later today. also it has been doing this for a few months now and it hasnt actually stalled out.
98bucket
Sep 27, 2013 02:19 AM
hell0curry
Apr 4, 2012 11:20 PM
joelmatt89
15
Nov 4, 2009 05:27 PM
Thatssojdm
Aug 5, 2008 07:59 PM
drock305
Nov 7, 2007 06:56 PM
