Water Disappearing and Engine Light
Old Aug 13, 2002 | 12:12 PM
LudeSpeeds's Avatar
Default Water Disappearing and Engine Light
Ok, I have 2 questions:
First: I seem to have a pretty decent water leak because I have to add water to my 93 Lude Vtec once about every 4 days. Problem is, I never see any dripping from my car when its parked. Any ideas or known problems?
Second: If I drive my car between 2 and 4 grand, my check engine light will come on but below 2 and above 4 it won't. My thinking is a bad O2 sensor. Any ideas or known problems.
TIA, J
Old Aug 13, 2002 | 12:18 PM
bgod's Avatar
Default Re: Water Disappearing and Engine Light (LudeSpeeds)
check all your coolant lines. could be a head gasket.
check the code for the check engine light.
Old Aug 13, 2002 | 12:25 PM
ViZ's Avatar
ViZ
Default Re: Water Disappearing and Engine Light (bgod)
check your oil to make sure no water is getting into it, if it is then it is most likely a head gasket
[Modified by ViZ, 1:26 PM 8/13/2002]
Old Aug 13, 2002 | 01:36 PM
LudeSpeeds's Avatar
No water in oil, I think I may have heard a hising noise coming from the front of the head behind the exhaust manifold. If it was a head gasket, would it have to be dumping water into the oil or could it be a head gasket problem without even touching the oil?
Old Aug 13, 2002 | 02:50 PM
ViZ's Avatar
ViZ
there are 2 ways to tell if you have water in the oil, one drain it and you should notice because it seperates, two the oil level will be high but if it was low to start (which is common in h22's because they burn oil a little bit) then you may not notice as much. If its bad though the oil will turn a lighter color all most a dookie brown.. but thats only when its really bad.
also make sure you have your radiator cap on correct, i can't remember if all hondas have the arrow but if it does make sure its pointed towards the overflow line on the side of the stem where the radiator cap is.
and i can't answer the engine light portion you should try to find what code is showing..
ViZ
and if i am wrong on anything please correct me people
[Modified by ViZ, 3:52 PM 8/13/2002]
the_dxB16
16
Dec 29, 2008 04:40 PM
obuhmyuh
Feb 20, 2008 11:15 PM
caminSi
Jul 27, 2006 07:52 AM
tek_civic
Feb 16, 2006 06:43 PM
ithrowpoop
Jun 12, 2003 03:19 AM
