oil leak from filter
Old Mar 23, 2009 | 08:55 PM
devin_hoang's Avatar
Default oil leak from filter
okay i have been noticing i have a leak in my oil filter. once i noticed it i changed the oil filter because i was thinking that the gasket on the filter was messed up. but it still continues to leak. i even checked if the gasket from the previous oil filter was there but it wasn't.
any ideas?
Old Mar 23, 2009 | 08:56 PM
highroller54's Avatar
Default Re: oil leak from filter
oil pressure sending unit.
Old Mar 23, 2009 | 08:58 PM
i have no clue what that is. i'm still a newbie. i'm learning slowly. i haven't encounter this problem before.
Old Mar 23, 2009 | 09:29 PM
Noch's Avatar
check to make sure the oil filter has the oring...and also make sure that it doesn't have two orings...that happened to me once, the oring didn't come off when i took the filter off.
Old Mar 23, 2009 | 09:31 PM
i already checked that. there isn't two cause i changed my oil filter and before i put it on i checked if it had the previous one.
Old Mar 23, 2009 | 09:32 PM
EK9r!der's Avatar
ok. now how long has it been doing this? it could just be a bad filter, who knows.
Old Mar 23, 2009 | 09:39 PM
i already changed my oil filter last week
Old Mar 23, 2009 | 09:40 PM
93egSLEEPER's Avatar
what kind of filter are you using?
Old Mar 23, 2009 | 09:42 PM
fram
Old Mar 23, 2009 | 09:45 PM
what is the number? should be a ph3596a i think
Old Mar 23, 2009 | 09:46 PM
yeah i guess. i dont know the number but i know for sure i got the right one
Old Mar 23, 2009 | 09:51 PM
jdm602's Avatar
sounds like you messed up the threads possibly. oil pressure switch has tappered threads so...no seal.
Old Mar 23, 2009 | 09:54 PM
i dont know. i dont know how i messed up the threads. i dont think i did.
Old Mar 23, 2009 | 09:55 PM
jdm602's Avatar
you sure its on tight? maybe something got stuck in the threads too. if not the maybe you have a cracked block. lets hope not. lol.
Old Mar 23, 2009 | 09:57 PM
i doubt that. i screwed that thing on real tight. but i checked the filter it doesn't have oil on it. i see a little puddle of oil under my oil filter on my block.
Old Mar 23, 2009 | 10:05 PM
SOHCNightmare's Avatar
PH3593A lolz
Old Mar 23, 2009 | 10:15 PM
jdm602's Avatar
i think he did a typo. there is no ph3596a. 6 is right above 3.
clean it all up and check to find where its coming from and report back with where and we will tell you how to fix. 123 go!
Old Mar 23, 2009 | 10:17 PM
where is the oil sending unit?
Old Mar 23, 2009 | 10:28 PM
jdm602's Avatar
Old Mar 23, 2009 | 10:29 PM
jdm602's Avatar
ignore the adapter for the oil feed. looks like that only without that oil line. its the sensor right above the filter. should have a wire attached to it tho.
Old Mar 23, 2009 | 10:36 PM
so if it was leaking from there, how would i fix it.
Old Mar 23, 2009 | 10:37 PM
would i have to take off my intake manifold to get to it?
Old Mar 23, 2009 | 10:38 PM
EK9r!der's Avatar
no you don't have to. just jack up your car.
Old Mar 23, 2009 | 10:41 PM
would i have to buy a new oil pressure sending unit?
Old Mar 23, 2009 | 10:43 PM
EK9r!der's Avatar
if the threats are messed up you might get away with re-threading it. if not you going to need a new one, and possibly re-threading the block also.
