ARP head studs for B18C5
Old Aug 13, 2002 | 12:05 PM
rambler's Avatar
New User
Default ARP head studs for B18C5
I will be removing the head off my C5 in a very short time and would like to get a set of ARP head studs.
The ARP application guide (which can be viewed here) does not show a kit for the C5. I have called ARP and they don't really know of the C5 and the differences with this setup and others. UGHH.
Anyway, they do make a kit for the B16A (part # 208-4601) which uses their 11mm X 1.5 thread pitch studs that are 7-1/8" (7.125") long. Given that the stock head bolts are 164mm long (6.456") are the 7.125" studs long enough to both bottom out in the threads in the block and allow room for the washer and nut? ARP also makes the same bolt in 7.250" but is this one too long? will it come into confilct with the other stuff going on in the head?
Please help.... if you have used ARP head studs please let me know what you used and how they are working out.
Old Aug 13, 2002 | 12:09 PM
RTW DC2R's Avatar
Default Re: ARP head studs for B18C5 (rambler)
I believe the B16 studs work. I think those are the ones I have but my car isnt back together yet so I dont know if its a problem yet.
Old Aug 13, 2002 | 02:19 PM
TurboR1391's Avatar
Default Re: ARP head studs for B18C5 (RTW DC2)
I used the GSR ARP head bolts for my rebuild and they work perfectly.
Old Aug 13, 2002 | 03:01 PM
austrian type-R's Avatar
Default Re: ARP head studs for B18C5 (Vonte')
I have ARP studs from Importparts in my B18C6 Euro Spec ITR engine and they fitted perfectly.
bow tie
Oct 21, 2008 12:03 PM
d16dcoe45
Oct 27, 2006 03:19 PM
9seccivicsi
Sep 20, 2004 10:55 AM
Nextelbuddy
Feb 26, 2004 11:46 PM
baonest1
Oct 17, 2002 06:29 PM
