Squeaking noise??
Hi guys,
My 91 hatchback has just recently (two weeks ago) started making this squeaking noise coming from the left front tire side. It comes and goes intermittently at both low and high speeds and doesn't seem to be connected to how fast I am going or reving or the brakes.
It's pretty wierd because it just starts randomly and then goes away for a like 30 minutes and then comes back. I have noticed that it has gotten worse in the last few days though.
Any ideas about what might be causing it and how to fix it?
Any help appreciated! Thanks
Axles usually make a clicking noise, click click click. Does it make the noise when you turn in one direction but not the other? if so I'd assume ball joint. If it makes the noise when your just driving along probably a worn bushing in the front suspension
Ya, it's mostly just when I am driving. It doesn't matter how I turn.
I will be swapping in a sohc zc in a couple months and I will check the axles and stuff then.
Is there a way to verify if it is a worn bushing? How would I do that?
Thanks
Thanks
RG5384
Apr 29, 2013 12:59 AM
