Fs: New in package oem parts! B16/B18C=HG, bearings,brackets, fly bolts, misc
Old Mar 23, 2009 | 06:55 PM
sweet's Avatar
Icon6 Fs: New in package oem parts! B16/B18C=HG, bearings,brackets, fly bolts, misc
here are genuine Honda items that have collected over the years from buildups and swaps. things that weren't used or needed. all items are brand new in HONDA OEM packages, unless noted!
below are the descriptions and Honda part #'s. for questions and pics just PM me. some items may be able to be shipped in a small envelope, which should only cost a couple $. others may need a small flat rate box or larger, so $5.50-11.00 range. but i should be able to fit quite a few smaller items in one package for the same price. so it will be more cost effective to buy multiple items. if you buy most or all of the items i'll give you a package deal! all prices listed are considerably lower than the cheapest price i can find from the discounted Honda dealerships. i will update as i find more parts that i can't find right now. LOL thanks!
3/24/09 UPDATE! i found another bag of new OEM parts, parts added!
92-95 Civic Hatchback REAR Fender liner/protector (set of 2 for both sides), Honda part # 74430-SR3-A00 = $15/pair
SOLD B16/B18C 81mm HG, part # 12251-P30-014 = $50
B18C Main cap bolts (set of 10, 6 for the girdle and 4 for the end caps) = $35
SOLD B16/B18 clutch to flywheel bolts (6 total), part # 90034-689-000 = $13 for the set
SOLD B series Flywheel bolts (set of 8), part # 90011-PH3-000 = $22 for the set
Shifter bushing bolts (x2, part # missing on bag), bolt "sleeves" (x2, part # 54114-SB2-000), bushing "brace" (x1, part # 54307-SB3-010), shifter lower dust seal (x1, part # 54109-SA7-000), lever ball seat (x1, part # 54110-SH3-003) = $20 for the set
Right Front engine mount "stopper bolt", slides through the rubber mount and the washer and nut goes onto it to keep the mount in place on the trans bracket, part # 90133-S04-000 = $8
SOLD Crankshaft thrust washers (set of 2), part # 13331-PR3-004 = $7
SOLD B18C Oil pump seal, part # 91212-PR3-003 = $4
SOLD B16/B18C Oil pan gasket, part # 11251-P30-004 = $17
Transmission housing seal, where the right side axle locks in place, part #
91205-PC9-711 = $5
B16/B18 cam seal, part # 12513-P30-000 = $4
SOLD B16/B18 REAR engine stiffener, block to transmission piece, part # 11950-P72-A00 =
$25
SOLD B16/B18 FRONT engine stiffener, block to transmission piece, part # 11960-P30-000 = $15
B16/B18C Main bearing pair (i have 3 pairs total, 3 lower and 3 upper for a total of 6), Green color, part #13344-PR3-004 & #13324-PR3-004 = $12 per set of 2
B16/B18C Main bearing pair (1 lower and 1 upper), Brown color, part #
13343-PR3-004 & # 13323-PR3-004 = $12 for the pair
B16/B18C Main bearing pair (1 lower and 1 upper), Blue color, part #
13341-PR3-004 & # 13321-PR3-004 = $12 for the pair
B18C Rod bearings, 1 pair of Green color, part # 13214-P72-003 = $10
B18C Rod bearings, 1 pair of Brown color, part # 13213-P72-003 = $10
B16/B17 Rod bearings, 1 pair of Brown color, part # 13213-P30-004 = $10
B16/B17 Rod bearings, 1 pair of Green color, part # 13214-P30-004 = $10
SOLD B16/B18 camshaft seals (1 set of 2 seals), part # 91213-PR3-004 = $8
B series injector to IM seals (set of 4), part # 16472-P10-A01 = $25/set
B16/B18C valvecover washers/seals (set of 8), part # 90442-P30-000 = $16/set
B series valvecover "chrome nuts" (only 3), part # 90213-PH3-000 = $5 for all 3
B16/B18C cam cap bolt/stud (only 3), part # 90014-PR3-000 = $10 for all 3
SOLD B series timing belt tensioner bolt (only the bolt w/washer), part # 90026-PR3-003 =
$3.50
Below are USED OEM GSR parts:
set of 24 OEM 99 GSR valvesprings (16 intake, 8 exhaust), from a stock head, removed for an upgrade----> $25 for the set
set of 16 OEM 99 GSR valvespring retainers----> $20 for the set
Old Mar 23, 2009 | 07:47 PM
sweet's Avatar
Default Re: Fs: New in package oem parts! B16/B18C=HG, bearings,brackets, fly bolts, misc
bump!
Old Mar 24, 2009 | 06:23 PM
sweet's Avatar
bump for new parts added!
Old Mar 25, 2009 | 07:36 AM
sweet's Avatar
Going up! Looking for someone to take this stuff and help me clean up! LOL
Old Mar 25, 2009 | 05:28 PM
DB2-R81's Avatar
25 Year Member
Hello Sweet,
Can you give me a total price with shipping on the following parts, these are all Honda OEM parts? My zip code is 98230. You can email me or PM, m_sasso@shaw.ca
Thanks!
Old Mar 25, 2009 | 05:54 PM
wolfenr1984's Avatar
$45 for the tensioner bolt, pressure plate bolts, and flywheel bolts. I got paypal right now. Shipping to 32607.
Old Mar 25, 2009 | 08:11 PM
sweet's Avatar
just to clarify, yes these are all genuine Honda parts. all NEW in the package, 99% never even opened and absolutely none of them used in any way whatsoever. and i can provide pics of any item/part i am selling before payment is made. it's no problem so just provide your email address and LMK what you need! thanks!
PM's sent!
Old Mar 25, 2009 | 08:40 PM
egluism33's Avatar
Hey do you have a obd1 gsr wiring harness i can buy?
Old Mar 25, 2009 | 08:50 PM
sweet's Avatar
Icon3 Re: Fs: New in package oem parts! B16/B18C=HG, bearings,brackets, fly bolts, misc
i don't have any more engine harnesses left, but i wish i could help you out though. i sold the last one i had about 1 week ago.
Old Mar 26, 2009 | 10:36 AM
sweet's Avatar
bump
Old Mar 26, 2009 | 06:14 PM
sweet's Avatar
some parts sold, others need to go!
Old Mar 27, 2009 | 01:17 PM
sweet's Avatar
Bump!
Old Mar 27, 2009 | 07:20 PM
sweet's Avatar
night bump!
Old Mar 28, 2009 | 07:47 AM
sweet's Avatar
Bump
Old Mar 28, 2009 | 08:05 AM
Pp to flywheel bolts and tensioner bolt sold. Thanks. Bump!
Old Mar 28, 2009 | 10:02 AM
sweet's Avatar
Yes, those items are sold!! LOL sorry I haven't had much time to update all my threads.
Old Mar 28, 2009 | 06:32 PM
sweet's Avatar
bump!
Old Mar 29, 2009 | 08:09 PM
sweet's Avatar
bump for the night!
Old Mar 31, 2009 | 08:01 AM
sweet's Avatar
Bump
Old Mar 31, 2009 | 07:48 PM
sweet's Avatar
night bump
Old Apr 1, 2009 | 08:47 AM
sweet's Avatar
going up!
Old Apr 2, 2009 | 09:44 AM
sweet's Avatar
afternoon bump!
Old Apr 3, 2009 | 02:45 PM
sweet's Avatar
Bump!
Old Apr 4, 2009 | 03:42 PM
Hey, thanks for the hardware! It showed up today and was exactly what I was looking for! I appreciate it!
Old Apr 5, 2009 | 05:28 PM
sweet's Avatar
no problem at all! i'm happy to help you out!
