installed a new cluster..now nothing works
Old Mar 23, 2009 | 05:01 PM
Mr. Chainsaw's Avatar
Default installed a new cluster..now nothing works
i have an si, it had a cx cluster, put in an ex cluster...nothing works. temp, fuel, tach, speedo, lights. when i turn the key on, engine off, the only light that lights up is the battery light. no srs, ses, or anything like they should when you do that. when i turn on the right blinker, it lights up on the dash, left turn does not light up. i checked every fuse known to man and nothing is popped. i tried putting the cx cluster back in, and it is doing the same thing. wtf
Old Mar 23, 2009 | 05:29 PM
jesterjess's Avatar
Default Re: installed a new cluster..now nothing works
I sucessfully replaced a stock DX cluster with an Si cluster. The DX did not have a tach, but the Si cluster did. I just plugged in 3 of the 4 connectors, and EVERYTHING works perfectly. However, if you have 4 connectors, maybe you need a 4 connector cluster.
Old Mar 23, 2009 | 05:51 PM
lhd dc2's Avatar
Try checking all of your plugs. Make sure they are in tight. Shouldnt be the new cluster if its doing that to your old cluster.
Old Mar 23, 2009 | 06:02 PM
got it. bad ground
Old Jul 30, 2009 | 01:42 PM
sanjiyan69's Avatar
where is the ground?
worx
Nov 7, 2012 06:10 AM
kcrxxx
Apr 2, 2008 08:13 PM
American.Graffiti
Nov 1, 2005 08:18 PM
chadmasterc
Jun 4, 2005 09:42 PM
akaEsCo01
Aug 25, 2003 10:46 PM
