Which ARP studs to use w/skunk2 mani/hondata gask.
Old Mar 23, 2009 | 04:56 PM
fizic's Avatar
Icon2 Which ARP studs to use w/skunk2 mani/hondata gask.
I finally picked up the Skunk2 intake mani for my GSR and
the stock intake studs are too short with the thick hondata gasket and and the skunk2 cast manifold.
I considered just backing out the studs a thread and a half but theres got to be a better solution.
What ARP fasteners would fit?
Size?
Part number?
Any help would be appreciated.
Old Mar 23, 2009 | 05:14 PM
a1320addict's Avatar
Default Re: Which ARP studs to use w/skunk2 mani/hondata gask.
IIRC, ARP 434-1301 is the kit you need.
Old Mar 23, 2009 | 08:13 PM
95skunkedgsr's Avatar
wow realy had no problem puttin mine on .. i did notice my injectors sat differ and had to move the injector spacers tho .. keep an eye on that
Old Mar 24, 2009 | 05:53 AM
killerpenguin21's Avatar
why waste money on arp.
check this
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/king-motorsports-intake-manifold-studs-puhlease-2035380/
when you run that part number in mcmaster carr's site they are the stock length studs. make sure you get the ones that are 10mm longer or more than what that number brings up...i made that mistake, and still spent less than getting arp's.
you can see them on this page in my build thread
https://honda-tech.com/forums/showth...180817&page=15
Old Mar 24, 2009 | 01:54 PM
fizic's Avatar
Thanks for the options!!
I havent looked at the injector fitment yet but I will before I proceed -
Im leaning towards the KMS set but I will still price out the ARP and then make the call.
EDIT: ARP priced at 178.00 canadian!!
Mcmaster Carr it is then.
Old Mar 25, 2009 | 07:29 AM
tegra2G's Avatar
I had a hondata intake gasket on my built LS, and all I can say is that it was a waste of money..
I found out the hard way, my advice is after about 3,000miles torque the intake nuts down again. 2 of mine came off, and left me stranded on the highway
Old Mar 25, 2009 | 09:57 AM
DAMotorsports's Avatar
i just went to autozone and got the studs i believe they were 8mm-1.25X40. it was only $5 and i used the stock nuts. no need for ARP.
Old Mar 25, 2009 | 10:06 AM
fizic's Avatar
I have had a few experiences w intake manifold bolts myself. I added a second gutted butterfly plate to lengthen the runners on my OEM gsr manifold - giving more low end tourque.-secondaries ran off an rpm switch...got decent numbers as well...but what I was getting at was I too had to retighten my mani bolts.
Even worse was my friend had a M62 JRSC on his gsr and believe it or not a few of the bolts to hold it on are INSIDE the blower housing accessed though a setscrew opening.
Long story short a bolt backed itself out and got jambed in the blower blades!
I will be checking these bolts daily.
Old Mar 25, 2009 | 06:39 PM
Fink29's Avatar
Medium Loctite
Old Mar 26, 2009 | 04:18 AM
illmatic118's Avatar
I can relate i put my hondata intake manifold gasket on and after about 4,000 ish miles i went to take it off and the nuts were really loose.
Old Mar 26, 2009 | 05:14 AM
egb18c5's Avatar
i believe in the instructions they said to retighten/retorque them after certain amount of miles/heat cycles
Old Mar 26, 2009 | 07:49 AM
fizic's Avatar
Fink29 - I now stock the blue(med) locktight with my sockets all the time...and my friend with the m62, when he called JR and ordered a new blower, he mentioned what happened and they sent him a tube of locktight along with the new blower.
WalkerGSR1
Sep 27, 2006 06:26 PM
aZnjCC
Aug 17, 2005 01:29 PM
jaystation
Jul 23, 2005 04:54 AM
SpoolnG2
Oct 28, 2003 11:40 AM
