cam!!!
Old Mar 23, 2009 | 01:45 PM
micktype r's Avatar
New User
Default cam!!!
hello boys my name is michael i live montreal my english is not good sorry for this!!
ok i have a block b18c5 stock
11:05 cr witch grs head
my head is a gsr p&p cnc job flow 300 cfm
springs ,retainer and valve is super tech
my intake is sk2 pro
tb professional product 68mm
injector of h22 jdm 345 cc
flyweel act 12 lbs
clutch stage 3
transmission is sir
my question is with can of cam is the best for my setup???
thanks you boys!!
merci beaucoup!!!
Old Mar 23, 2009 | 01:51 PM
Combustion Contraption's Avatar
Default Re: cam!!!
Rm m22x
Old Mar 23, 2009 | 01:56 PM
micktype r's Avatar
New User
Default Re: cam!!!
rm m22x is the name of the cam
and how many hp witch this cam!!!
Old Mar 23, 2009 | 02:10 PM
k20coupe's Avatar
Default Re: cam!!!
that's one pricey cam
Old Mar 23, 2009 | 02:14 PM
micktype r's Avatar
New User
Default Re: cam!!!
what lol!!!!|!
Old Mar 23, 2009 | 03:03 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: cam!!!
I have those cams and a very similar build to yours and made 191 SAE whp without any cam gear tuning on a stock B16a2 head. I really like the cams, very easy to tune, make great power in VTEC, similar to the Skunk2 pro 1's. You should be able to make more than I did with your setup as long as you have a good tuner and tuning system. The Pro 1's will give you more midrange and low end but can be a little harder to tune.
I will be installing a ported GSR head this spring and tuning my cams and will be looking forward to the results.
Old Mar 23, 2009 | 03:59 PM
Rocket's Avatar
Default Re: cam!!!
Cams with hotter primaries like those from Rocket Motorsports (M22x, etc) or Skunk Pro Series will give best satisfaction.
Cams like JUN3 or similar copies of have smaller primaries that cause the power band to die out before (causing the famous "dip") being able to properly engage VTEC.
Old Mar 23, 2009 | 05:40 PM
micktype r's Avatar
New User
Default Re: cam!!!
ok ok what is the (dip)
i understand is the skunk 2 pro or thre mr the baest cam for me!!!
and whith sk2 pro1 or pro2
Old Mar 23, 2009 | 07:49 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: cam!!!
see my last post. That's your answer.
Old Mar 24, 2009 | 09:18 AM
Rocket's Avatar
Default Re: cam!!!
Search for JUN3 dynos.
Old Mar 24, 2009 | 10:07 AM
C_Rock77's Avatar
Default Re: cam!!!
As compared to what? Rocket's cams are no pricier than any other camshaft on the market!
2kdrift
Mar 15, 2016 02:32 PM
1988montecarlos
11
Jan 26, 2014 05:14 PM
flavio
Aug 25, 2009 03:39 PM
SR20S13
Jul 12, 2007 07:12 PM
cjohnson_2
Nov 25, 2003 06:13 PM
