oversize intake valves
Old Mar 23, 2009 | 12:41 PM
boostonweekends's Avatar
Default oversize intake valves
has anyone done head work involving oversize intake valves? I have a z6 that im turboing and want to get as much air in as possible. i guess what im asking is how big can i go and where can i find them (the valves that is)
Old Mar 25, 2009 | 11:08 AM
Default Re: oversize intake valves
anyone?
Old Mar 25, 2009 | 01:29 PM
jlicrx's Avatar
http://www.laskeyracing.com/shop/valvetrain.htm
Old Mar 25, 2009 | 05:33 PM
abnaasefmb's Avatar
I’ve never seen the point in just putting wider valves in the head without the associated head work. If you don’t port the runners and widen the opening of the valve seat so that the entire system is now 1mm wider, then all you’re doing is putting a bigger obstruction in front of the airflow path. This totally changes the air velocity characteristics and therefore the flame propagation. The good thing is adding a turbo will overcome many of the limitations of a stock head that might be a problem for a NA set up. If I was you I would spend my money on headstuds, a better cam or sometime of the like. Good luck.
SirRevvs
Oct 14, 2010 10:32 AM
DJYoshaBYD
Dec 9, 2009 10:59 AM
baysic r
May 27, 2009 08:57 AM
Andre
Feb 24, 2004 07:13 PM
teg92
Dec 15, 2001 10:51 AM
