Honda S2000 Honda S2000
Clutch or Master cylinder proglem????? help
Old Mar 23, 2009 | 12:13 PM
AllMotorRP's Avatar
Default Clutch or Master cylinder proglem????? help
Last Thursday I was driving my car and noticed the clutch felt lighter, so I put some brake fluid in. Did'nt help much, Friday I was driving to Atlanta and put 300 miles on my car that weekend. By the time I got back home my clutch felt pretty louse.
I have been loosing fluid for awhile but not much I just fill it up alittle each couple weeks. I'm thinking I have a clutch master cy problem.
Do you guys think its the cy or clutch itself or a clutch alignment, or even some air got in the line?
Also I am loosing fluid but I neved see anything in the bay or ground.
The car has 97,700 miles, bought it at 64,000 and im sure its the original clutch.
please help, thanks
Old Mar 23, 2009 | 06:19 PM
AllMotorRP's Avatar
Default Re: Clutch or Master cylinder proglem????? help
anyone know whats going on.......?
Old Mar 23, 2009 | 06:24 PM
90Civic Si's Avatar
try bleeding it, if it eventually feels lousy its probably your clutch master cylinder. check to see near the clutch pedal if it may be leaking there.
Old Mar 23, 2009 | 06:33 PM
Targa250R's Avatar
be professional
It's pointless to make an assessment of the clutch disc itself if you're losing fluid. Address the hydraulic problem first.
Replace the clutch master and/or slave cylinders, whichever is leaking. Pull back the boot on the slave cylinder and check for signs of leakage. Get down under the dash and check for sludge/drips where the pushrod enters the master cylinder. If both are leaking, replace both and bleed the system.
Old Mar 23, 2009 | 07:41 PM
S2KFTW's Avatar
if you're losing fluid it's either the clutch master cylinder or the slave cylinder. try bleeding the slave cylinder and see how the clutch feels and if it still weird.
hannslebo
Mar 24, 2009 01:53 PM
Lb1atx
Sep 7, 2007 05:16 AM
Greenery18
Jul 8, 2005 04:22 PM
DriveSideWays
Aug 27, 2004 05:06 PM
vincent97gsr
Oct 10, 2002 03:41 PM
