anyone ever raise a civic before?
Old Mar 23, 2009 | 11:16 AM
raiden571's Avatar
Default anyone ever raise a civic before?
I would like to raise my 91 civic hatch about 2 in. anyone ever do this before with just coilovers or springs. its going to be runnign through the woods, so no making fun, only serious inquires. i imagine the biggest prolem will be the articulation of the cv-joints.
Old Mar 23, 2009 | 11:19 AM
jhammond_82's Avatar
Reject Papi
Default Re: anyone ever raise a civic before?
i would assume that coilovers jacked up would work pretty good. just watch your axle angles. i would also assume that noone has ever done this before at least your not lifting it for dubs,
Old Mar 23, 2009 | 11:39 AM
scottmog's Avatar
LOL
Old Mar 23, 2009 | 11:40 AM
scottmog's Avatar
http://cache.jalopnik.com/assets/res...en-Civic-2.jpg
Old Mar 23, 2009 | 11:46 AM
dephtone's Avatar
You may want to look at coil expanders or shims. I know like Advance/Auto Zone used to sell them where you put what almost looks like a C-Clamp in between your coils and it lifts it, I don't remember how much, just remembering seeing this for like tow vehicles n whatnot, but will work with any coil spring application.
Old Mar 23, 2009 | 11:53 AM
BLU CIVIC's Avatar
Track Advocate
this guys is on a local forum, i can get you in contact with him if you want...these were taken Saturday at an EF meet
just a height reference...
Old Mar 23, 2009 | 11:59 AM
Don Napier's Avatar
Import Alliance
That is amazing....
Old Mar 23, 2009 | 01:20 PM
89s1's Avatar
Installing integra springs and shocks will raise the car.
Old Mar 23, 2009 | 01:51 PM
KoDKingVegeta's Avatar
Originally Posted by Mog
That might be possible, with the back anyways. If you take the steelies and turn them around so the part that goes over the drum is now backwards, and you weld or mount the rim somehow to the tractor tire. That might work. The front, no clue. Unless you convert the front to drums.
Old Mar 23, 2009 | 02:06 PM
Reject Papi
is that a real picture? or was it photochopped? because, the rear tire on that thing, is in the water, but not wet. just curious. and why would you have to convert to drums? i've seen trucks with huge tires on them, not necessarily with tractor tires, but still. disc brakes would still work. wheel spacers anyone?
Old Mar 23, 2009 | 02:07 PM
Yes its "real" http://www.youtube.com/watch?v=c5GnBvpFnzA
Old Mar 23, 2009 | 02:11 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Off-roading!
Old Mar 23, 2009 | 02:13 PM
88Hatchy's Avatar
You would want to use the springs and shocks from the heaviest civic or integra, my guess would be one of the DC2 integras.
Old Mar 26, 2009 | 05:07 AM
raiden571's Avatar
that is awesome, yeah let me know what he says, or if i can get ahold of him to ask him some q's. i have about 150acres to plan on and it is already prepped for quads/dirtbikes. ill just have to make the trails a lil wider and make some creek crossings out of logs/cinder block
the car obviously wont be driven on the street this way if anyone is wondering.
Old Mar 26, 2009 | 07:02 AM
~sp33~'s Avatar
EFB055
I can't believe that Civic boat thing actually moved under it's own steam.
Old Mar 26, 2009 | 09:47 AM
raiden571's Avatar
and yeah, that was horrible. was that vid from the u.s?
Old Mar 26, 2009 | 09:51 AM
No hes from Canada.
Old Mar 27, 2009 | 07:23 AM
raiden571's Avatar
that makes alot more sense then^.....anyone ever get more info on the green, off/road civic? really curious about his setup
thanks
Old Mar 27, 2009 | 10:59 AM
rattlecannedEF's Avatar
red green is awesome.
poor civic.
Old Mar 27, 2009 | 11:46 AM
hushypushy's Avatar
How much of a raise do you want? If you put stock DA (90-93 Integra) springs and shocks it'll raise it an inch or two.
Old Mar 27, 2009 | 01:04 PM
b20turbojason's Avatar
i would put spacers between the strut cap and strut tower. but even with lengthened studs you can only go so think. just like the leveling kits for 4wd trucks.
Old Mar 27, 2009 | 03:25 PM
Singlecam4dr's Avatar
What about accord struts and springs? They should lift more than integras yes? Aleast the springs will, im not sure if the struts would fit though.
Tutu
15
Jun 23, 2005 08:05 PM
HatchbackSiVtec
Mar 18, 2003 11:16 PM
CenturionCivic
Mar 8, 2003 10:03 AM
civic_91
Jan 1, 2003 05:03 PM
Chris_
Feb 20, 2002 12:32 PM
