2 clutch cylinders?
Old Mar 23, 2009 | 11:15 AM
[ej]Jonathan's Avatar
Lord of the idiots
Default 2 clutch cylinders?
ive seen civics with 2 clutch cylinders, whats the purpose of that?
Old Mar 23, 2009 | 11:45 AM
dividedas1's Avatar
Default Re: 2 clutch cylinders?
um like the slave & and the master?
the master cylinder holds clutch (brake fluid dot 3) and when you push on the clutch pedal it pushes through the clutch lines to the slave cylinder which i used to engage/disengage the clutch. its a simple hydraulic system and works much like a hydraulic brake set up.
hope this helps.
PaulMc
May 18, 2014 05:04 PM
hannslebo
Mar 24, 2009 01:53 PM
FLCivic
Jun 30, 2004 03:48 PM
g00se
Mar 8, 2004 06:11 PM
Hard2Find
Mar 12, 2002 03:17 PM
