d16z6 swap Qs
Old Mar 23, 2009 | 10:39 AM
crxblues's Avatar
Default d16z6 swap Qs
i have a 1991 crx dx with a d15b2 and im going to be doing a d16z6 swap in it next month. just trying to get everything i need together before i start the swap. when i swap out the motor should i also swap out the exhaust manifold or will the dx manifold be fine? i dont have the stock d16z6 mani so if i cant use the dx mani i will most likely get aftermarket headers.
Old Mar 23, 2009 | 10:41 AM
shaggyeg6si's Avatar
Default Re: d16z6 swap Qs
You can use the original header, that'd be best because you know it already fits your car. I had a problem trying to put a stock header back on mine, and I think there is a difference between the DPFI and the MPFI headers, one is shorter and can't fit the other.
Old Mar 23, 2009 | 10:46 AM
crxblues's Avatar
i have a dpfi motor now so does that mean i can still use the original manifold with the d16z6?
Old Mar 23, 2009 | 02:31 PM
dc5itracer's Avatar
Just get some ebay headers.im pretty sure the d15b2 headers are smaller than the z6 ones dat motors gonna be choking lol
Old Mar 23, 2009 | 03:01 PM
crxblues's Avatar
thanks for the help. i think im going to order some headers off of ebay. is megan racing decent quality?
Old Mar 23, 2009 | 04:31 PM
crxblues's Avatar
so i ordered some megan racing headers off of ebay after reading some good reviews. my next questions is is it alright to use a lightened flywheel with a new stock clutch?
Old Apr 7, 2009 | 07:13 AM
dc5itracer's Avatar
I would just go with a comp clutch stage 1 and lightned flywheel
Old Apr 7, 2009 | 09:40 AM
crxblues's Avatar
Originally Posted by dc5itracer
I would just go with a comp clutch stage 1 and lightned flyheel
thanks for the relply but that was weeks ago. i already got the motor and tranny in the car now. why do u recommend a comp stage 1 clutch? i put the flywheel in with a stock replacement clutch set and it seems to work fine.
Old Apr 7, 2009 | 09:50 PM
got00rice's Avatar
i got a question for u crxblues. anyways which tranny did you used? cause i know the d16z6 is an obd1 engine and you're car if its a 88-91 civic/crx then its obd0.
Old Apr 7, 2009 | 10:23 PM
Ghett0_ed's Avatar
when it comes to the trannies that dosnt matter
88-91 used cable transmisions and 92+ uses hydro trannies so the z6 one wouldnt work since its hydro
Old Apr 8, 2009 | 05:31 AM
crxblues's Avatar
yeah when it come to d-series trannies it doent matter much just as long as its a cable tranny. unless u feel the need to convert to hydro. i used a si tranny for the d16z6. getting my triming covers today sso i have it running how it should today.
Old Apr 8, 2009 | 01:05 PM
got00rice's Avatar
ok im just asking to see if you convert it to hydra instead of keeping it cable. cause im planning to convert my 91 si hb into obd1. so i was just wondering thanks.
blue1992eg
Jan 4, 2010 03:31 PM
GarageAlchemist
Feb 23, 2006 04:12 AM
blkhatch92
Nov 7, 2005 06:39 AM
hondafrk
Feb 5, 2005 05:31 AM
RexLine
Nov 24, 2003 06:02 PM
