clutch always engaged
Ok so I went to leave for work today and I couldn't put my car in reverse. (did nothing but grind) So I turned the car off put it in revese and started my car again, this time it acted like the clutch was stuck and stayed in reverse even with the clutch in. Basically the clutch seems to be constantly engaged and i have to hard shift all the time. As far as no everything in the transmission is stock (clutch, flywheel, etc). The previous owner said they replaced the clutch master cylinder. any help is appreciated. thanks
Since they said they replaced the MC, I would first look at the slave cyl. They're pretty cheap, replace it, bleed the lines and see how it goes, if its still not working, Check all your clutch lines, if they're all good, replace the MC.
