Rev racing valvetrain (my first build)
Old Mar 23, 2009 | 05:14 AM
civicboyvtec's Avatar
Default Rev racing valvetrain (my first build)
just bought rev racing valvetrain which includes vavlvesprings, titanium retainers, 8 flat and 8 dished valves, bronze valve guides, and valve stem seals, and now am looking for some cams to go with them, don't really know what will work with my setup, i have been looking at cams like pro2, blox stg3, Buddyclub4, and bc3 cams but can't really make a choice, all of this will be going in b16a pr3 head
any my setup is,
b18c4 block ( same as teg si b18c block)
81.5mm jdm teg pistons or p30,
89mm eagle crank with eagle rods,
arp rod, main, and head bolts,
acl bearings and piston rings,
cometic 2 layer head gasket,
itr intake manifold port matched with 68mm throttle body,
pr3 head port and polish, 3 angle valve job, and head skimmed .0040
rev racing valves, springs and retainer, bronze valve guides and stem seals,
and what compression with this setup am i looking at, and what cams will work best with this set up, Amer
Old Mar 23, 2009 | 07:48 AM
00b20vtecoupe's Avatar
Default Re: Rev racing valvetrain (my first build)
cr should be pretty high ide say in the 12's but not possitive but im running that valve train and with the cr ide say either run pro 2's or buddy club 4's im currently running the bc4's made great high end power.
Old Mar 23, 2009 | 11:45 AM
so revracing stuff can take quite alot of beating from pro2s and bc4s?
would be great if anyone can confirm what cr will i be running and i have read in alot of posts that the setup i am building is pretty good but havnt really seen anyone with this setup, would be great if someone has got a setup like i am building with some dyno graphs, Amer
Old Mar 23, 2009 | 12:26 PM
should be a pretty beasty setup but if you look around for a link i know there r compression calculators sumwhere where u type all ur info in and it tells u wat it should be.
c5 teg
Sep 12, 2013 12:49 PM
civicboyvtec
Mar 31, 2009 05:01 PM
office888
May 27, 2007 10:51 PM
Demonlude
Mar 13, 2007 01:07 PM
pg_thao
Apr 22, 2002 08:44 AM
