Turbo or all motor?
Old Mar 22, 2009 | 06:51 PM
Crx_b16's Avatar
Default Turbo or all motor?
I really need some advice on this. I just bought a long block Gsr with a b16 head, thats im looking to built to put in my CRX. What i need to know is would it be good to built it for turbo with a b16 head on a gsr??....would it be better to just do a all motor built?? And how much should i be looking to pay a shop to do the built. Any advice is greatly apreciated.
Old Mar 22, 2009 | 06:57 PM
JDMgunmetalCRX's Avatar
Default Re: Turbo or all motor?
cheaper if u did it yourself.
Turbokits can be bought anywhere really....ebay, craigslist (alot of good **** there) or junkyards. any turbo will work as long as u got the right internals to hold the boost.
All motor is the more expensive alternative and unlike turbo's they dont lag on you. All motor takes alot of time and money. so if your looking for a cheap way to get up into the high HP you should probably stick to turbo.
Old Mar 22, 2009 | 07:38 PM
ZC DOHC CRX's Avatar
All depends on what your wanting out of it
IBTL
Old Mar 23, 2009 | 06:57 PM
Crx_b16's Avatar
what internals should i use to built it...??? and do you know of any website or forum that shows you how to turbo ?? step by step because this is my first time doing it.
Old Mar 23, 2009 | 07:20 PM
jhammond_82's Avatar
Reject Papi
stock internals will hold over 300 hp. thats pretty good for a decent driver or track car.
Old Mar 23, 2009 | 07:37 PM
forged low compression pistons and rods will keep you and ur engine safe under high boost.
just look up how to install turbo's
its alot of work and tuning to get ur turbo right. but it does pay off
Old Mar 23, 2009 | 09:11 PM
realhomemadeturbo.com
Stock internals will hold just fine for 350+ on a good tune and some e85
There is TONS of info out there. Do some searching and you should get good results
Old Mar 23, 2009 | 09:40 PM
Ass$nyper's Avatar
Pirate General...YARRRR
This thread failed before it started.
eg6-trans
Dec 27, 2007 05:25 PM
CRX_Type_R
Nov 19, 2004 10:49 PM
quik sol
Dec 13, 2003 04:03 AM
teg_girl
May 18, 2003 02:02 AM
jspek29
15
Jan 1, 2003 06:03 PM
