how to put a obd2 b20 vtec in a 95 obd1 coupe?
Old Mar 22, 2009 | 06:10 PM
gnccracer20's Avatar
Default how to put a obd2 b20 vtec in a 95 obd1 coupe?
the b20 vtec im looking at buying is obd2 my 95 coupe EX is obd1 obviously so what all do i need to do for it to work without swapping the insides of distributors out
Old Mar 22, 2009 | 06:19 PM
autox228's Avatar
Default Re: how to put a obd2 b20 vtec in a 95 obd1 coupe?
Use your stock ex harness, change your dizzy to obd1 bseries, obd1 injectors and obd1 alternater.
Old Mar 22, 2009 | 06:28 PM
so can i jus use my obd1 LS dizzy and my LS alternator an injectors
Old Mar 22, 2009 | 06:36 PM
autox228's Avatar
bseries vtec dizzy, my bad
Old Mar 22, 2009 | 06:48 PM
will it plug right up to the harness in my car right now on my LS motor
Old Mar 22, 2009 | 06:57 PM
jxhxb's Avatar
if your short on cash and have an obd2 alternator u can always convert it to obd1 by soldering the certain color wires,but u need the plug from the obd2 harness. i dont know the exact color to color chart but thats what i did swapping a obd2 motor in my obd1 civic.
its not hard to do but if your swap came with an obd2 harness u can cut it and convert it.
Old Mar 22, 2009 | 09:25 PM
asarr's Avatar
New User
I am working on putting in a B16B into my 93 civic Ex. I am studying the wiring from the D16Z6 and The CTR B16B. It is possible the use the OBD 2a wiring harness but there is some wiring that will need fabrication. I am starting to lean toward using the OBD 1 to OBD 2a conversion harness. There are adapters for the injectors. This is more popular than fabricating your own conversion harness. I want to use the factory ECU because it is set up for my Type R engine performance.
jlowellintegra
Sep 3, 2010 07:34 AM
Civic483973
12
Jun 11, 2010 08:55 PM
Rash Ej1 SiR
Mar 21, 2006 09:59 AM
cthan3o3
13
Jul 31, 2005 08:27 AM
mjrage
Jun 24, 2004 09:53 AM
