lose weight?
what could i take off my stock 91 civic hatchback out of the engine compartment that it doesnt need to lose some weight and make it look over all cleaner?
its a bit jumbled as is.
i hate it
i hate it
get rid of all your AC units.
take out your coolant resevoir.
take out your washer resevoir as well.
get a half-sized radiator.
relocate your battery to your trunk.
get a different air intake delivery system.
also if you really wanna do it big, do a wire tuck.
don't take out your coolant reservoir you can relocate it but don't take if off your car need it your car sucks coolant out of that and puts excises coolant in there just remove all the emissions stuff and get a cleaner looking intake and intake manifold and exhaust manifold(headers) motor mounts wire tuck or re wrap wires in better looking wrap relocate battery and repaint you engine bay
http://i30.photobucket.com/albums/c3...7/IMG_2412.jpg
i know for a fact i've posted this link before. just, noone wants to search any more. idk. anyway, here's a link, and if you look in the integra faq, there's one in there too. http://www.superhonda.com/forum/f5/w...-coupe-265880/
I wouldnt use that link he provided for any kind of real numbers. They are all way off, just an estimate thats on the heavy side.
Here are some numbers from my crx when i stripped it. All measurements were done with a doctor style slide scale in the same day with me holding the item in a <1 lb box.
All items are from an 88 Crx hf, if there are two items(matching sides like speakers) then they are measured together and totaled.
AC System Brakedown Total 56.5 (note this is ALL heating/cooling stuff)
-Pump+bracket 25lbs
-Tubes condensor, resivoir 11lbs
-AC core and small fittings 7.5lbs
-Blower fan, wires, heater core, small parts and plastics left 13lbs
Random things
Spare tire 20.5 lbs
Door panels 9
Rear curvy plastic panels, metal brackets, and trim(rear strip) 19lbs
center plastic/storage box, entire center console, 14lbs
Front speakers 2lbs
rear speakers 6.5lbs (yeah i dont know either)
Misc parts, floor mats, brackets, 13lbs
Dash 14.5lbs
carpet plus remaining trim 13lbs
radio climate stuff etc, 6lbs
Misc bag full of bits and pieces 4.5
Dash supports and remaining plastic heater/cooling tubes 3lbs
Switched to momo seat 11lbs lighter
passanger seat 16lbs
I couldnt measure my rear hatch glass which i have changed to about 3 lbs of lexan, but i really dont think it weighed that much, 10lbs max (mine came out in a bucket/vaccume)
Battery, switch to a nice small one, or use a lawnmower battery like me. havent weighed, not much lighter than my old one though. 5lbs max
My total weight savings are 208.5 as it sits. I know its more info than you wanted(sounds like you just want engine bay) but there ya go.
-Pump+bracket 25lbs
Random things
Spare tire 20.5 lbs
Door panels 9
Front speakers 2lbs
Dash 14.5lbs
u should change ur battery to a NRG-cell battery..theyre only 11.5lbs vs ur stock heavy one!!...theyre cheap-ish..lol..go on on the website ..http://www.nrgcell.com/
X2 I DID ALL THIS AND IT LOOKS NICE IN THE ENGINE BAY
Superhatch
24
Oct 29, 2008 06:14 PM
jwaked
67
Apr 23, 2004 03:24 PM
