94-01 Integra QP window removal?
Has anyone been able to remove the 2 rear side windows without destroying the mouldings or breaking the glass? If you did please fill me on on how you did it. Thanks in advance
This is near impossible, I just got done replacing the quarter panel on my teg and I got about halfway through cutting it out with a brake cable from a bicycle before it broke, one person on the outside and one on the inside, kinda likea sawing action, I know from honda these are about 225 a piece and you cannot buy the molding seperate from the glass.
Good luck
Good luck
If you could find someone who has an inductor you could get it out without messing it up. It just heats up the metal where the urethane is. I dont know how it works exactly. I have seen some glass guys using them and the glass comes out so easy.
Other aproach is the electric knife but you can almost bet your gonna mess it up.
It's possible, you just have to be patient and cut it out from the inside. I had a glass guy come out when I put a new quarter on a teg and thats what he did.
http://store01.prostores.com/servlet...ss-Heat/Detail
there you go, might be better off trying with the wire then if you mess up buying new windows
Sinner
May 3, 2008 02:04 PM
