Need some primer help guys.
So I'm going with the featherfill G2. Now i heard since its a polyester primer that I'm going to need to go over it with a urethane primer after, and after that a sealer? Now is that the right way of doing things?
So i was thinking 2-3 good coats of featherfill G2 then blocking my way up to 600 grit. Then a urethane primer?? blocking it, then a nice smooth coat of sealer then shooting the base? Of course letting everything cure in the steps.
TIA
TIA
Not bad at all. I know a real thin coat of bondo will level things out. If its a minor imperfection would high fill level things out.
I'll post some pics tomorrow.
