my g23 vtec build.
well the time has finally come most of my parts are in and the motor will be going to the machine shop on friday to be bored .20 over. I already got the water pump back which is an f23 housing with an h22 cog pressed into it. purchased some acl bearings, k20a 11.5:1 compression pistons. so this will be my thread hopefully I will be finished this month with the build. I will post pictures of everything as I go. helpful comments will be appreciated!
everything that I personally do will have a description and how to with pictures. some stuff has to be sent to a machine shop like the water pump, bore and hone of the block, and plugging the oil drain ports in the head. but everything else will have a write up.
sorry about the amount of time its taking me. I will have pictures up of the stock f23 block and all the parts going in including the new modified water pump for the build. I was going to do it friday but I just got home from the army hand to hand combatives instructor course and was completely wiped out. so I will have it up wednesday. cause that's when I am dropping the block off to be bored .20 over to accept the k20a oversized pistons.
spunautosports
Dec 19, 2006 09:05 AM
