radiator core support swap (t bar) swap
Old Mar 22, 2009 | 12:36 AM
RICE POLICE SIP's Avatar
Default radiator core support swap (t bar) swap
Just curious... If the top part of the core support is damaged and that's it.. Can it be replaced instead of the whole entire radiator support? I've searched and this was the closest I could find..
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/fact-fiction-%7E-radiator-support-aka-t-bar-frontend-conversion-56k-warning-1700836/
http://corporatemonster.com/parts/tbar.jpg
this is a pic of an EF "t bar" but i'm wondering about an EG or Del Sol "t bar"... I know if it's possible that it's got to be drilled out and it's not a bolt in affair like the EF.. Can this piece be bought on it's own? TIA
Shane
Old Mar 22, 2009 | 08:32 AM
Default Re: radiator core support swap (t bar) swap
Bump....
Old Mar 22, 2009 | 08:34 AM
iwanttokillgod's Avatar
yes it can
Old Mar 22, 2009 | 09:30 AM
victor.m's Avatar
Wondering about this too, is it welded onto the chassis or just bolted to the top and the bottom end of the core?
Old Mar 22, 2009 | 09:37 AM
its spot welded drill out the spot welds remove weld on new one not that hard you people need to take some initiative and try things on your own
Old Mar 22, 2009 | 07:14 PM
Are you talking to me?
Old Mar 24, 2009 | 10:00 AM
yes
Old Mar 25, 2009 | 06:35 AM
yes
Kind of thought so... Yeah let me just jump into some project without doing a little research.. It's called common sense! If it's never been done before then sure I'll jump into it and learn as I go but since it HAS been done, I'll do my research first. Thanks!
What projects have you done without doing any research at all?
Old Mar 25, 2009 | 10:55 AM
doing research is fine but asking for the answer is a cop out
quartermilerun
12
Sep 3, 2014 06:11 AM
thegatekeeper14
Aug 6, 2011 09:57 AM
mattyfo0z
Aug 18, 2010 01:05 AM
ESP.net
Northwest (Sales)
Jul 19, 2009 06:07 PM
i_VTEC
16
Oct 22, 2008 04:46 AM
