How do i remove this piece...EF
Yea. Best bet would be to roll the window down all the way, and remove the door panel. Then check out where they are and what u will need to remove them with out breaking them. If i were u i would look for a Helms online manual. Tells u everything about the car and how stuff works/and to repair it/ remove/ replace it.
O yea ur going to need to remove the mirror for sure.
you don't have to remove the door panel, but removing it would give you more room to work with so you don't accidentally break any of the clips. If you're not worried about breaking the clips because you are replacing it anyway, then just pop that sucker off and pop on the new one
I actually figured them out the other day on my eg not sure if its the same. Ill try to explain it. Take the panel off. Get a pair of needle noise pliers squeeze the clip. Pull up on the molding a little bit and it should start coming up some. Once you see it come up a little bit get a small flat head screw driver. Go to the front of the door and you can see the small white clip push on the middle of the clip and it should just come right up. I believe theres 5 of them. Do the same for the rest. I started from the rear and worked my way towards the mirror.
naaa im trying to save the clips cause im just going to go to the junk yard and rip the new ones off (carefully) and use my old clips from my original piece on my car!
