How do i remove this piece...EF
Old Mar 21, 2009 | 08:05 PM
JP Patches's Avatar
Default How do i remove this piece...EF
The piece right below the window
idk exactly what its called
(note: this is a verrry old picture of my car )
Old Mar 21, 2009 | 08:08 PM
jrcashflow's Avatar
Default Re: How do i remove this piece...EF
i have an ef try. That has some clips pull the molding up. You have to lower the window.
Old Mar 21, 2009 | 08:09 PM
JP Patches's Avatar
Pull the molding up?
what do you mean...
Old Mar 21, 2009 | 08:10 PM
-16V-'s Avatar
pretty sure u have to remove the door panel to get to those clips?
Old Mar 21, 2009 | 08:15 PM
JP Patches's Avatar
i have to remove the interior door panel to get to those clips?
Old Mar 21, 2009 | 08:22 PM
-16V-'s Avatar
Yea. Best bet would be to roll the window down all the way, and remove the door panel. Then check out where they are and what u will need to remove them with out breaking them. If i were u i would look for a Helms online manual. Tells u everything about the car and how stuff works/and to repair it/ remove/ replace it.
O yea ur going to need to remove the mirror for sure.
Old Mar 21, 2009 | 08:25 PM
JP Patches's Avatar
alright coo thanks
Old Mar 21, 2009 | 08:41 PM
-16V-'s Avatar
alright coo thanks
No prob man. Good luck!
Old Mar 21, 2009 | 08:44 PM
aasarsak's Avatar
you don't have to remove the door panel, but removing it would give you more room to work with so you don't accidentally break any of the clips. If you're not worried about breaking the clips because you are replacing it anyway, then just pop that sucker off and pop on the new one
Old Mar 21, 2009 | 08:46 PM
Linh.'s Avatar
I actually figured them out the other day on my eg not sure if its the same. Ill try to explain it. Take the panel off. Get a pair of needle noise pliers squeeze the clip. Pull up on the molding a little bit and it should start coming up some. Once you see it come up a little bit get a small flat head screw driver. Go to the front of the door and you can see the small white clip push on the middle of the clip and it should just come right up. I believe theres 5 of them. Do the same for the rest. I started from the rear and worked my way towards the mirror.
JP Patches's Avatar
naaa im trying to save the clips cause im just going to go to the junk yard and rip the new ones off (carefully) and use my old clips from my original piece on my car!
revn9k
May 26, 2022 03:33 AM
Turboredteg
May 12, 2007 07:01 AM
themurrell
Feb 21, 2007 08:32 PM
kornerk12
Nov 12, 2006 06:21 PM
jipr
Dec 6, 2005 08:40 AM
