Would 96-00 civic shocks/springs fit a 92-95 honda civic?
Old Mar 21, 2009 | 07:48 PM
Mrbigaznboi's Avatar
Default Would 96-00 civic shocks/springs fit a 92-95 honda civic?
Would 96-00 civic OEM shocks/springs fit a 92-95 honda civic? I need to buy some shocks and springs for my 93 civic.. and cant find any.. would 96-00 fit?
Old Mar 21, 2009 | 08:35 PM
SOHCNightmare's Avatar
Default Re: Would 96-00 civic shocks/springs fit a 92-95 honda civic?
I believe so.
Old Mar 21, 2009 | 08:52 PM
thumper64's Avatar
I want to say that the rears are the same for shocks, but the fronts are different. Koni has a different part number for the EG and EK fronts. The rears are the same. The springs are the same.
88-00 Civics and like 91?-01 Tegs use the same dimension LCAs in the rear, and the top hats will interchange. I have tophats from a 92 Integra on my 93 CX because I had some lying around that were in better condition than my Civic ones.
If you can swing it, Koni yellows and Eibach Ground Controls are nice. Just don't buy Skunk2 springs. They suck. Hard.
batallic's Avatar
https://honda-tech.com/forums/suspension-brakes-54/koni-shocks-97-coupe-onto-94-coupe-2529531/
88-00 springs are the same
Old Mar 21, 2009 | 09:01 PM
trustdestruction's Avatar
springs will fit for sure.
however, for the rear shocks, you'll either need to use 96-00 LCA shock bushings, or file or grind your stock bushings down to be narrow enough. The 96-00 rear shocks bracket is narrower than the 92-95.
For the front they should fit perfectly, besides that the brake line bolts won't line up.
Old Mar 21, 2009 | 09:26 PM
92eg_sirs's Avatar
yeah 96-00 lower controll arms are thinner and the 92-95 lower controll arms are too fat for the ek shocks but u can file the eg control arms thinner too fitt the ek shocks but fronts are the same good luck
hotxcivic92
Dec 12, 2007 07:37 AM
Tuesdaynightfever
Mar 23, 2007 09:14 AM
vizsual00
Apr 28, 2005 06:09 PM
