new to honda. been with GM for a wile, could use a tip on ECU chip for 91 b18a1
ok, so everyone says get a hondata chip for my 1991 acura integra that has a b18a1 with quite a few mods. i can not find this chip anywhere? i went to the hondata website and it dosent list a chip for a 1991 b18a1? is this motor and ecu the same in 1992? if not where can i find this chip? thaks and i hope honda is more forgiving than the Ecotec lol..
Check with the FAQ's in the tuning forum, you've got other options besides the Hondata.
and what was said above is also true. its not a drop in chip.
if you really want to maximize the potential i would convert your car to obd1 and get it tuned by a professional , as no chips are "perfect" setup for your car as every motor is different
chips are good if up are looking to stay a near stock for the time u own the car but if u are planing to turbo/sc/na bilde your car later go with a hondata but if that relly in not i your bugit then go with a chiped ecu from phearable.com or xenocron.com and when u get your car to the point u need that tune to run it then the is software that can tune obd0 as for the power of it it is not like obd1 but i can be dune
my car is not stock, i have port an polished head, fuel pump, fuel rail, injectors, full exhaust from header back, C.A.I. and the normal plug upgrades, wires, im not to sure of all as i purchased the car not assembled and put it together. my reason for ECU upgrade is it will not stay running after idle drops to 700 RPM. i have ajusted idle and still no results.
like he said a lil further up i would just convert to obd1 if you were looking for just a quick street car to drive everyday its not too expensive or hard either
