Do i need to add vtec wiring on type r
Old Mar 21, 2009 | 06:32 PM
Dukie432's Avatar
Default Do i need to add vtec wiring on type r
i just dropped in a 2000 jdm type r. it came with full wiring from the motor to the ecu. it also came with jdm type r ecu. im dropping it into a 93 civic coupe. the old motor was not vtec but does that matter? if it comes with all the wiring do i still need to add wires? any help please
Old Mar 21, 2009 | 07:49 PM
jptyper's Avatar
Default Re: Do i need to add vtec wiring on type r
http://www.phearable.net/tech/wiring/wiring.92-95.jpg
Old Mar 21, 2009 | 07:59 PM
SI_frankenstein's Avatar
You should not need to add anything, IF you have the complete engine harness. You already have the ecu and you said you had the harness or wiring so you should be good.
Old Mar 22, 2009 | 09:32 AM
Dukie432's Avatar
does that include the knock sensor I read about
Old Mar 22, 2009 | 10:29 AM
Inliner's Avatar
youll have to wire vtec and knock sensor to the plug on the passenger side strut tower if your car did not come with vtec.
Old Mar 22, 2009 | 10:32 AM
Dukie432's Avatar
What's on the passanger tower?
Dukie432
30
Mar 31, 2009 04:37 PM
92b16vx
Apr 25, 2005 01:18 PM
dfuzz3
Jun 20, 2003 06:04 PM
Peter K
Jun 26, 2002 05:44 AM
4g4me
Apr 22, 2002 09:23 AM
