need 12v power civic coupe
I want to install two LED light tubes in the area under the steering wheel and same on the passanger side. Each requires 12V power. I have no experience installing these. Does anyone know how to do this?
I have a 2005 honda civic ex 2 door.
Thanks!
Thanks!
how exactly do you hook it up to that fuse, I do not want to do any damage to my electrical system. Also, does that mean that I can no longer use the power outlet for my cell phone, navigation system, etc?
Get a test light and look for acc. power at ur fuse panel, find yourself a connector that will fit in the panel, splice into your tube wires and plug it in. there should be a ground wire bolted close to the fuse panel. you can use that same ground. I did this for my fog lights, works light a champ.
easy way go to autozone and get u the adapter that changes ur cig lighter to 3 cig lighter or 12v. acc what ever you wanna call it.....or be cool and dont put them in at all!!!!
