idle surge? (searched)
Old Mar 21, 2009 | 05:03 PM
texaszcrx's Avatar
Default idle surge? (searched)
ok i have an idle surge and i figured out that if i plug the lower port just inside the throttle body it fixes my problem, however i have tried taking out the fitv and cleaning it to no avail, also tried to block it off with a piece of plastic acting as a plate between the fitv and the throttle body (didn't work) also tried to take the spring and cap off and switch them around to close the valve permanently but still won't work, the only fix i have is a piece of duct tape over the hole. is there anything else that would cause this other that the fitv, that would go away when plugging the port? please help, i cant stand to drive the car with the suging idle. btw its a b18c1.
Old Mar 21, 2009 | 08:14 PM
90_EX_Civic's Avatar
Default Re: idle surge? (searched)
have you tried your idle air control valve?
Old Mar 23, 2009 | 06:24 AM
texaszcrx's Avatar
anymore ideas?
Old Mar 23, 2009 | 07:05 AM
5litereater's Avatar
Some people sandwich a piece of a pop can in between the FITV and the intake mani...
Old Mar 23, 2009 | 07:17 AM
texaszcrx's Avatar
i tried doing that with a piece of thin plastic but it didn't work. thanx for the reply.
Old Mar 23, 2009 | 07:21 AM
mouab18c1's Avatar
try covering up your tb with your hand and see if your car dies..if not then you have a vacuum leak..and no it wont suck in you hand...
Old Mar 23, 2009 | 10:24 AM
texaszcrx's Avatar
when i cover the upper port inside the throttle bocy (iacv) the car dies, when i cover the lower port (fitv) the idle returns to normal however all of my attempts to block the fitv have failed or there is something else causing this.
Old Mar 23, 2009 | 05:36 PM
ej_squadron's Avatar
it could be a vacuum leak.spray brake clean or carburator cleaner around the tb when vehicle is surging.if u spary the cleaner and the idle becomes normal,u have a vacuum leak where ever u sprayed.if that doen't work.remove you iac valve and clean the valve with brake clean.check the gasket if it is damaged in anyway.try that first and let me know how its doing!
Old Mar 23, 2009 | 06:30 PM
texaszcrx's Avatar
thanx for the reply, ill try that as soon as i can and report my findings.
Old Mar 23, 2009 | 07:51 PM
rayvo's Avatar
unbolt the three bolts that holds on the valve on the underside of the throttle body... unscrew the two phillips that hold on the plate on the left end of thevalve.... inside a white plunger with with a ball in the middle, tighten the plunger by the slots clockwise till tight.... to put back on follow remaval steps reverse... replace lost coolant ....should do it. worked me and many other cars ive owned
Old Mar 24, 2009 | 05:56 AM
texaszcrx's Avatar
ive already done that, i tried tightening, cleaning, and then even reversing the spring and retainer.
Iloveyourhonda92
Apr 11, 2015 07:46 PM
da9crxsi
Jun 4, 2012 09:52 AM
okkritikos
Dec 17, 2010 03:22 PM
vtec94civic
Aug 9, 2005 03:35 PM
caLiH22A
Aug 24, 2004 08:05 PM
