nasty fluctuating idle
Old Mar 21, 2009 | 01:21 PM
h22 kid's Avatar
Default nasty fluctuating idle
i did a swap into my 96 accord with and h22a1 and i am having fluctuating idle problems. i check all my vacuums and gaskets and everything is good. i bought a new iacv and that seems to have not done anything... anyone have any ideas that may be of any help??
thanks
Old Mar 21, 2009 | 01:30 PM
gasguzzlr's Avatar
New User
Default Re: nasty fluctuating idle
is it a slow or fast idle fluctuation ??
Old Mar 21, 2009 | 01:31 PM
h22 kid's Avatar
its slow... goes from 1k to 3k
Old Mar 21, 2009 | 06:11 PM
meanshyguy's Avatar
It's probably your FITV (fast idle thermo valve) It's located under your TB, that thing sucks, I don't even know why they put them or our cars, but there's a way to clean it
https://honda-tech.com/forums/honda-accord-1990-2002-2/cleaning-iacv-fitv-tb-1844067/
This will surely help!!
Old Mar 21, 2009 | 08:23 PM
h22 kid's Avatar
thanks i'll get started on it tomorrow maybe that would be it i hope so
Old Mar 21, 2009 | 10:59 PM
gstrudler's Avatar
make sure you bled your coolant properly as well
Old Mar 21, 2009 | 11:29 PM
h22 kid's Avatar
how do you bleed the coolant?? does the car have to be on?
Old Mar 22, 2009 | 09:28 AM
meanshyguy's Avatar
The way I do it, or the way I was taught, with your engine cold, open the bleeder bolt, which is located by the thermostat area, it's a 12mm bolt I think, then open your radiator cap and start filling up until the colant starts coming out of the bleeder bolt, then close the bleeder bolt and then the radiator. That's how I was taught to do it.
Old Mar 22, 2009 | 12:52 PM
gstrudler's Avatar
^ do this, but leave your rad cap off, start the car and let it get to full operating temp, then put the radiator cap on. this is what it says in the helm's anyway; makes sure all the last little bubbles are out as the fluid expands as it warms up i suppose.
Old Mar 22, 2009 | 03:45 PM
h22 kid's Avatar
i did that and water was shooting everywhere and the idle stayed... i think it might be the FITV. is the fitv suppose of be loose on the inside where the two metal nipples clink against each other
Old Mar 22, 2009 | 07:29 PM
gstrudler's Avatar
?? there should be a big white plastic plunger on the inside; it should be secure. if it's loose, you can screw it down with a flathead screwdriver iirc.
Old Mar 22, 2009 | 09:04 PM
h22 kid's Avatar
well its hella loose.... and its yellow and has now way of screwing it down... idk where to go from here
Old Mar 23, 2009 | 12:43 AM
gstrudler's Avatar
hmm, sorry, sounds different from the h22a4 then. i'm pretty sure it shouldn't be loose though.
Old Mar 23, 2009 | 09:52 AM
h22 kid's Avatar
sorry i opened it again and i saw those notches... i tightened it and then i noticed when i started the car it had a nice consistant idle for five seconds unlike before where the idle just started when the car ignited. i think that my FITV is bad completely...
Old Mar 23, 2009 | 10:09 AM
meanshyguy's Avatar
I hate that fitv, just get an aftermarket tb that doesn't have it, lol, jk, try to find another if cleaning it didn't work.
Old Mar 23, 2009 | 04:01 PM
h22 kid's Avatar
i have an aftermarket tb and am going to put that on to see if the idle goes away and if it does i will get another fitv if it doesnt then its off to bleeding the coolant again and searching for vacuum leaks.... i know its not vacuum leaks cause i rebuilt the entire motor with new gaskets everywhere so might be those stupid hoses connected wrong... let you guys know
Old Mar 24, 2009 | 12:23 PM
H22-EGHatch's Avatar
New User
I am having the same problem with my h22 swap. i tried the fitv but it did the same thing yours did, idled constant and then went back to spiking. Let me know if the aftermarket TB works for you.
Old Mar 24, 2009 | 08:53 PM
h22 kid's Avatar
good news everyone that aftermarket TB WORKED!!!! so that tells me that my FITV was bad... thanks everyone for the great help you all did....h22 EGHATCH your FITV might be bad but try cleaning the IACV first if that doesnt help then get another TB
Ef4doorwagon
17
Apr 6, 2014 03:31 PM
JFantastic
Mar 11, 2013 08:15 PM
mkrieger500
Mar 2, 2011 12:53 PM
240punk
Jan 20, 2011 03:46 PM
96accordexproject
Feb 2, 2008 01:41 PM
